Stroker for a steal
Old Sep 25, 2010 | 12:30 PM
jaycenk's Avatar
Default Stroker for a steal
Anyone looking for one here you go. I would have gone and looked at it but I have no cash right now so I thought I would share the wealth like the Dems are are always saying to do lol. http://tampa.craigslist.org/hil/pts/1950462491.html
Old Sep 25, 2010 | 12:50 PM
kinglt-1's Avatar
No!!!!!!!!!!!! It has a eagle cast crank, run like a ************!
Old Sep 25, 2010 | 12:54 PM
jaycenk's Avatar
I run an eagle cast with no problems. for lower power they are fine just don't shoot any NOS at them.
Old Sep 25, 2010 | 03:21 PM
kinglt-1's Avatar
there has been quite a few threads in the past about the eagle cast crank breaking under na power! Search and you will see...
Old Sep 25, 2010 | 03:30 PM
formula vincent's Avatar
"****" ...the good deals always pop up when im broke . not fair .
Old Sep 25, 2010 | 03:35 PM
Rob94hawk's Avatar
I've read this numerous times on many forums. Apparently the stock nodular cast iron crank is stronger than the Eagle cast.
Old Sep 25, 2010 | 06:18 PM
fuzchunk's Avatar
my eagle cast crank broke on an exit ramp after 15k I wont run another
Old Sep 25, 2010 | 06:32 PM
speed_demon24's Avatar
361rwhp 383 LT1. Sign me up!!!
Old Sep 25, 2010 | 06:42 PM
BizZzatch350's Avatar
Moderator
It's a steal for a reason
Old Sep 25, 2010 | 07:32 PM
jaycenk's Avatar
Not going to get into another eagle debate. I posted it for anyone looking. You could most likley pick it up for 1500 and throw the crank away and still sell everything on it or in it an make money and still have a good block to work with. It is in the car running, if it runs ok no reason you couldn't tear it down and build it. Headers and Y alone are worth 300 used, plus o2's at 60 set used and injectors for 150 used and even if you sold the heads and cam for 600 which is a fair number and the entire valve train with the heads for another 100 then what are you realy out. 290 bucks and you still have valve covers, block, intake, rods, pistons, timing set, pan... It's not a bad deal for someone looking. Just depends on how you look at it. What you do with it is your own buisness. Just thought I would throw it out there.
Old Sep 25, 2010 | 08:43 PM
stevo9389's Avatar
*** edit
not the guy i thought it was
Old Sep 25, 2010 | 11:26 PM
Wicked94Z's Avatar
hey negative nancy cut it out
Old Sep 26, 2010 | 01:16 AM
RamAir95TA's Avatar
What a piece of ****.
