So my builder recommends a high volume pump
There are some that have stated that the spring that comes with the 10554 pump is the same spec as the GM white spring. I cant confirm this but your engine builder can rig up a contraption to test the max pressure of an oil pump.
I am running the stock pan and I have that funky negative pressure spike at 5K RPM. It drops then bounces back up instantly. Has something to do with the oil sloshing around and some folks who encountered this have installed the Moroso pan to eliminate it. IMO, the stock pan works but its a crapshoot as to whether you will have the negative spike issue.
Was thinking about this. $155 is pretty damn pricey though and from what I've seen on Herron's web site it doesn't even come with the gear.
It is only the housing - no gear is included.
