Alternator not charging battery ???
Old Oct 4, 2010 | 08:13 PM
quik95lt1's Avatar
ok wow.....i just went out and messed with mine and low and behold the thing wouldnt charge.....i run a jumper cable from the alternator case to the battery post and bam 14.5 volts......gonna run a 4awg wire from the case straight to the battery
Old Oct 4, 2010 | 08:36 PM
airfix's Avatar
Glad you got it figured out.
Old Oct 4, 2010 | 08:47 PM
MattSapp95_T/A's Avatar
Originally Posted by airfix
Matt, I see you relocated your hood release cable Did you need a longer cable? I'm guessing you just routed it through the wheel well?
No used the stock cable just drilled a small hole on the back side of the wheel and ran it through...really easy like 15 mins
Originally Posted by starbucks
Thanks guys all it was was a bad ground i used some 10 gauge wire to gounrd the alternator to the head, does this sound big enough?
GREAT!! I am glad it fixed it for you!! I use 2 gauge...may be overkill but it has been working a while
Sweet glad it helped you out too!!!
Old Oct 4, 2010 | 08:58 PM
airfix's Avatar
Awesome thanks, Gonna have to do that this winter.
Old Oct 5, 2010 | 07:58 AM
Fastbird93's Avatar
How's this for funny, and quite related. I was just chasing this exact same issue on my car. Powdercoated Alternator housing, AND powdercoated the accessory bracket. First put it all together.....got about 10 volts. Then it hit me...powdercoat. Filed the mounting points clean on the alternator and the accessory bracket. Got it up to 13 volts, but still short......then it REALLY donned on me.......backside of the accessory bracket where it touches the motor. Damn........should have had some foresight there. Grounding strap here I come.
Old Oct 5, 2010 | 08:05 AM
quik95lt1's Avatar
yep ive had a low voltage prob in my car since day one always ran around 13ish and at WOT it would drop to like 12.3....this explains it cause i had my original bracket all painted and the block too so my original ground wasn't even that good........i put that strap on it last night and for the first time ever i saw 14.2 volts at my XFI and ignition box I'm souped!!! More spark!!! lol
Old Oct 5, 2010 | 11:35 AM
Glad I was able to help..... 1 step closer to that 9 sec pass!!!
Old Oct 5, 2010 | 12:06 PM
quik95lt1's Avatar
i know i could possibly make a wee bit more power now with the ignition getting full voltage........every bit helps!!!! going from 12.2 to 14.5 volts has gotta make the spark stronger!!
