LT1 OBD1 vs OBD2 tuning software.
Out side of the cost and the limited licensing witch one do you prefer,
OBD1 or OBD2 is one better that the other?
It looks like Jet and LT1 edit are the only choices of OBD2.
I down loaded the Jet demo, it looks very complex.
Took me all of 30 min to do the OBD1 Swap....also its cheaper however I recommend socketing your PCM and having extra flash chips that are already programmed and ready to go just in case you fry one.....ask me how I know lmao
It deletes the rear O2's and Crank Position Sensor.
I understand the reason for the rear O2 delete but is there an advantage
to deleting the crank position sensor?
