Shoot me in the face, header bolts too close to fit wrench on
Old 10-25-2010, 10:46 AM
  #41
the_merv's Avatar
Originally Posted by SS RRR
So dent primaries instead of purchasing a smaller head size bolt which are readily available. Smart.
Bolts were purchased..still had to clearance the spot for the BRACKET, and that was after grinding it.
I would expect you to have figured that out..but I can see why not when you drive a mid 12's 395.3 SR car.
It's loud and it smells alrite..smells like fail..
Old 10-25-2010, 11:07 AM
  #42
Village Troll
SS RRR's Avatar
I don't care what you had to do. This isn't about you other than your suggestion to dent a primary to make a bolt fit. As stated, smart.
Old 10-25-2010, 11:12 AM
  #43
the_merv's Avatar
Wow..I'm shocked. Usually you are one step short of rubbin my ***** when it comes to anything I post, or my Camaro..
This isn't about you other than your suggestion to dent a primary to fit a bolt. As stated, smart.
I prefer the term caressed..and yes, it is smart, its called improvising.
Good day to you sir.
Old 10-25-2010, 11:38 AM
  #44
Village Troll
SS RRR's Avatar
It's unnecessary is what it is. No reason to dent anything when there are smaller bolt head sizes available that make header installs virtually painless and less timely.
Old 10-25-2010, 12:59 PM
  #45
quik95lt1's Avatar
Originally Posted by speed_demon24
5/16 12 pt arp head bolts.
yep thats the solution and take a long box end wrench and grind the box end down thin so it fits and then heat it up and bend it to what you need...........thats what i did on mine and it works like a champ......took a sharpe and labled the wrench as lt1 header tool and tossed it in my glove box lol
Old 10-25-2010, 01:23 PM
  #46
AChotrod's Avatar
Mike if you took the tools out of your glove box and put them in a tool box, you might just loose enough weight to get your 9s NA. JK!!!!!
Old 10-25-2010, 01:33 PM
  #47
quik95lt1's Avatar
i knew somebody was gonna say that lol.......yea if i can get this thing running good again it may have a shot at it next weekend......i got the race brakes on it dropped a ton of spinning and unsprung weight.......think the WB02's on the FAST went bad trying to fix it now......went 10.40 @ 130 poppin and farting all the way down the track yesterday lol
sorry OP didn't mean to lol
Old 10-25-2010, 07:36 PM
  #48
pillarpod's Avatar
that made my night
Old 10-25-2010, 07:41 PM
  #49
Young Maro's Avatar
I went through the exact same process bro, you will be pulling your hair out with those 12 point bolts. You need some 6 point 5/16 bolts. I grinded down a few of my wrenches and tried every trick in the book with my Dynatech headers. You will eventually be able to get them threaded down, but good luck getting them tight!
If I EVER install headers again I will make sure to get 6 point bolts in the smallest acceptable head size.
Old 10-25-2010, 08:13 PM
  #50
RamAir95TA's Avatar
@ smashing headers to get bolts to fit.
Quick Reply: Shoot me in the face, header bolts too close to fit wrench on
