Torque converters
Old Oct 11, 2010 | 11:13 PM
marc97taws6's Avatar
I have a YANK SS3600 and am satisfied. Austin (355z28) uses a Circle D converter and his car runs strong!
No excuse to not get a 3600! I wish I would have went with a 4000
Old Oct 12, 2010 | 06:38 AM
bowtienut's Avatar
I recommend the Yank SS3600 hands down.
I've run it in everything from a stock cammed LT1 motor in the Impala, to the current 7000 rpm motor in the Impala, and currently behind a ZZ3 cammed Vortec crate motor in my 4900 lb pickup. I've run lots of the popular converter brands and stall speeds, and this one is the most versatile of all of them.
It drives WAYY better than an Edge 3400 and slightly better than a Vig 3000.
Old Oct 12, 2010 | 06:55 AM
meine96ws6's Avatar
Yank SS4000 for me.. should be going in next month...
Old Oct 12, 2010 | 06:40 PM
rufrntn's Avatar
Will I need to get a tune after the stall?
Old Oct 12, 2010 | 08:27 PM
trilkb's Avatar
I have a TCI superstreet fighter 3500 that i picked up for 160$ used. So far so good, TCI is known to be hit or miss, from what i hear its more "hit or slightly miss" as they can crap out a few months down the road. I am very happy i went with a 3500, anything lower and i probably wouldve been disappointed. like everyone else says go atleast 3000rpm. EXPECT to loose a load of MPG's if you do city driving. If i city drive, i might get 200 a tank.
I would scan the forsale section, people sell some NICE converters on here, yank, vig...whatever. I myself dont see the point is buying a new converter, when a used one can work perfectly well. Make sure its a lock up as well.
Be sure you smarten up on install if you dont know how, honestly, they arnt hard. weekend or even 1 day could do the job with proper tools and parts.
so my input would be, go high quality used (since money is a problem). Higher quality used converter is better then a crappy new one. Get a decent stall 3200-3800...get a lock up. Get a trans cooler as well. And DEFFINETLY, read up on how to properly install one. If its not installed right, it will probably cost you your transmission.
Old Oct 12, 2010 | 09:26 PM
gregrob's Avatar
I would never buy a used converter unless I sent it straight in to be checked out / freshened up.
Old Oct 12, 2010 | 09:50 PM
defaultexistence's Avatar
I'm buying one from here...after reading the info i see no reason to not go with it...and i dont care about brag name brands...
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
FTW!
After you read the entire listing ,Let the opinions and hating begin....
Old Oct 13, 2010 | 02:58 AM
Wicked94Z's Avatar
Originally Posted by defaultexistence
I'm buying this one...after reading the info i see no reason to not go with it...and i dont care about brag name brands...
FTW!
i like the billet front cover in the picture, then in the description part it's just a stock cover that's not misleading one bit for the average clueless 18 year old LT1 owner
Old Oct 13, 2010 | 03:06 AM
94lt1white_bird's Avatar
haha werd. ^
Old Oct 13, 2010 | 03:25 AM
Cam95Maro's Avatar
FTW!
my question is ...are you sure you want a non lock up ?
On another note I bought a 2800 stall and had in car for a month then trashed it cause it wasn't enough I didn't think so definitely listen and go biggerw
Old Oct 13, 2010 | 08:26 AM
quik95lt1's Avatar
Originally Posted by gregrob
No I dont. I'm an M6 car, I have friends who run them all and I like the way the ATI's perform the best.
Talk to Ed Wright, I believe Abare, and a LOT of other fast guys who have tried most of the converters out there, and stick with ATI.
Besides I wouldn't be giving someone a "part number" I would have them call ATI and have them put together something application specific...
Yes your absolutly right I was about to order one then i found out they were non lock up units and i had to lop the end of my input shaft off to run one. Probably would have put me in the 9's but I'd neva drive the car again picture driving a wet sponge around lol......for a track only car the 8" ATI is perfect for the street its suicide lol
Originally Posted by 96capricemgr
Those cars you are talking about use 8" Treemaster non-lockup converters not really something appropriate for a street car. Believe about 4200 is as low a stall as you can get those in.
ATI absolutely makes a good product but I don't think they have a 9.5-10" lockup high stall 4L60E unit. Which is what the OP should be looking for.
Exactly its a great race only highh rpm converter....
Originally Posted by rufrntn
I just ordered a 2800 stall edge converter from probuilt. What else will I need? Probably some kind of tune?
Gonna need fluid, filter, and a new seal for the front of the trans, also id invest in a external trans cooler as well....it will last forever if you dont overheat it...heat is the killer....im driving around a 5000 vigilante with a biggg external cooler mounted up in my front bumper right in the air and I never get hotter than 175* on a 90* day.....I would go higher than 2800 thou
Originally Posted by Wicked94Z
yea.... with lock-up there's no reason to be that conservative on the converter. Edge does make a good converter, they're a local shop. A lot of quick cars down in san diego are running their stuff. not 4L60Es though.
Yep I'd bump up that stall........and yea edge does make a great converter I got a 2400 towing converter in my truck and it hammers with the car on the back!!!
3400 minimum. You'll thank me later.
yep 3600 FTW!!!
Yep i agree Pat, either a SS3600 or a vigilante 3400-3600 is your winner.
Yes most likely you'll be on the limiter on ur WOT shifts because of the increased slippage at WOT.
Yep go big or go home lol.....3600 is your answer and being a lockup theres no worries about driving it.
Old Oct 13, 2010 | 01:49 PM
  #32
TheTransporter69's Avatar
+1 love the yank ss3600
and tune may depend, I think you shouldn't normally, but I've heard u can get cretin problems that a tune can fix like stall wall. I didn't get a tune with mine works like a champ.
Old Oct 13, 2010 | 02:12 PM
  #33
LSWHO's Avatar
Stall wall is an issue with OBD1. An OBD2 car does NOT require any special tuning for a stall.
  #34
timelord's Avatar
P.I. Vigilante.
I have Rick Abares old 4400 non lockup in my car and it is a daily driver.
Funny thing this one is non lock up and at 65 mph it turns 200 RPM less than the Coan 3200 lock up I had before it.
Car runs great,street and strip.
Old Oct 13, 2010 | 06:46 PM
  #35
Your right,..i posted the wrong part link,Thats what i get for posting when i shoud be sleeping... here's the right one to the OP with lockup,
http://cgi.ebay.com/ebaymotors/4L60E...item483ce41407
And, I don't know if your saying I'm clueless and/or 18?.... for the record I'm 33 and have owned/raced/modded/built 3 of these f-bodys so...it seems your a little clueless on opinions ? People here are such *********
Old Oct 13, 2010 | 06:57 PM
  #36
rufrntn's Avatar
Hey dude ummm he wasn't Exactly calling u a clueless or 18 but he's saying the picture is not even the part u will get.
Old Oct 13, 2010 | 07:08 PM
  #37
hmmm... even still... judging/buying a part by a picture instead of its description is a little bassakwerds anyhow..
Of course i'm going on a limb here but, 18yr olds can read these days too right?
Honestly i didnt even "read/look at "the generic picture ...i read the description.
ya think maybe they do that so they dont have to use a thousand different pic's for all the converters they sell?
Old Oct 13, 2010 | 07:48 PM
  #38
trilkb's Avatar
i think they do it cuz they suck.
A proper company has a picture of the product they are selling.
just my .02
Get the yank SS3600
Old Oct 13, 2010 | 08:09 PM
  #39
Wicked94Z's Avatar
Old Oct 13, 2010 | 08:10 PM
  #40
just my .02
Get the yank SS3600
They do......it's pictured in the description ........
why does the product suck? i assume by your statement that you have has personal experience with one from them?
