Whats a good cam to go with?
#42
#43
#45
I don't have to post to have you discount them. You already did.
I already said I'm going to port my own. It'll be a while, but you can all prove me foolish when I post my results. However keep in mind it would only be smoothing the airflow NOT pulling too much material. I've done some decent reading and research. I'm not an idiot. As much as you guys like to think I know what I know. I never claim to know more than I do either.
I will buy TFS 21s eventually. But I'll try hand porting first.
#46
I'm not saying anyone can dumbass. I'm sorry, but that's an LE head right? are you saying that you got bad results from an LE head?
You are either saying that's a bad set of heads or that you have just thrown up evidence of a bad port job, that's actually evidence of a good port job.
So tell me. If that's an LE head, is LE trash now?
#50
Sorry I lumped you in with SSRRR, speed and ramair95ta.
I do now realize you may be operating on your own accord.
I threw it off? I responded to another person talking about heads and made a comment about diy porting done right.
Also smoothing out airflow equally in all ports will make an uneven flowing head remain uneven. Like-wise to the evenflow head staying evenflow. (thoughts arrive like butterflies)
Also wouldn't some cylinders benefit from better head ports due to poor intake design/flow to certain cylinders?
#52
I will ask again.
Is it really fair to post numbers taken at .800" lift and not .600" lift to illustrate port to port inconsistency?
#53
Your graph lacks the incremental detail to accurately determine the numbers in question at .600". The broken lines of any given cell dont appear to have any significance to the values of 2, 3 or 4. I have however determined that the range of any given cell is indeed 12. Based on this, your graph can not be accurately read.
I will ask again.
I will ask again.
162cfm cyl 1
167cfm cyl 7
169cfm cyl 3
174cfm cyl 5
I learned to read graphs in 2nd grade.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
#54
Your graph lacks the incremental detail to accurately determine the numbers in question at .600". The broken lines of any given cell dont appear to have any significance to the values of 2, 3 or 4. I have however determined that the range of any given cell is indeed 12.5. Based on this, your graph can not be accurately read.
I will ask again.
I will ask again.
Or...
He threw that up to prove his point... though it's flawed.
Flawed? Oh well if you want to argue hand porting and it's imperfection, then you can argue that EVERY SINGLE LE head will flow differently. You show A SINLGE HEAD, and act as if EVERY SINGLE LE head will be similar??
This is funny, cause you are claiming hand porting is inconsistent at the same time claiming they'll all flow consistently inconsistent. Yet the very nature of inconsistent will tell you that none of them will flow the same and therefore your ONE SINGLE head theory on inconsistency itself is flawed and completely unsubstantiated.
You've certainly proven your case.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Sure hope you can follow that. Maybe bring out another graph that proves your theories on how I know nothing.
#55
Evidently LE2 heads guys are now running .800 lift. Congrats guys, that's awesome.
Or...
You've certainly proven your case.![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Or...
#57
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
Deal. I promise I will learn to properly read your graph.
If you promise to answer my question.
Now enhanced with large bold font so you cant miss it.
Come on I am meeting you half-way here.
#58
https://ls1tech.com/forums/11649027-post102.html
Hell that was easy. Not verbatim, but might as well be.
Are these two examples of you saying he flows them consistently? Cause it appears in both examples you are badmouthing his consistency.
Now, back to you being an idiot...
#59
