Building motor... need HELP!!!
What heads should i run?
What cam should i run?
What CR should i look to run?
Keep in mind that my budget isnt infinite since I am a student?
I appreciate any and all feedback.
Thanks
Thanks
Is there a target ET/RWHP/FWHP goal that you're looking for? Depending on a few things a stroker motor may not be what you need. Additionally, what current modifications do you have (drivetrain, exhaust, intake, etc.) as this will play a major part in your budget. Can't have the motor without the supporting modifications! eagle forged rotating assembly= $1200+
Patriot heads= $1000 heads come assembled
Cam= $350 if i cant find a used one
RRs= $300 Comp cams or Harland Sharp or Comp Cams 1.6s
Timing Chain= $100
Pushrods= $50 used set of trick flows
Oil Pump= $40 Melling
Injectors= idk probably go with 30lbs/hr
Fuel pressure regulator= used one for cheap
Use a stock fuel pressure regulator
Your rockers are missing guide plates unless you go with S/A + you need to make sure the push rods are the correct length
Missing Tune
Opti?
Water pump?
Machine work for the block?
Putting together the engine?
If the eagle kit is ballanced neutral you need to change to a neutrally ballanced fly or flex plate
Hub for keyed crank or have yours broched
Valve cover modifications
Lifters?
and what ever else you may need as far as oil filter, plugs, wires, coil, ICM, Sensors, and more than likley all radiator and heater hoses unless they are newer.
lifters= ls7 lifters
new water pump and opti will be in store thinking about doing the full msd kit
and whats the ICM?
You could build a cast botton end with FORGED pistons
Good heads
Mtached cam
and a Nitrous kit and be around 500hp to the ground.
this would save you a ton of money and im sure you would be much better off with the power. a 355 can save you on machine work as well...
Check out www.cnc-motorsports.com great prices and tons of lt1 stuff.... i got almost everything from there
Stock fuel pressure because any tune done buy most anyone is going to want stock fuel pressure. Changing the fuel pressure throws off so many things in the tune its not funney and it wont make you more power. clearancing isn't hard at all but making sure rods don't smack the cam.... kind of important. I agree with 95z28onjuice. A 355 with the right piston, used AI or LE2 heads and the right cam will make good power. only thing is you would need to get a dyno tune with street testing to get it ***** on.
I also agree with a budget 355 bottom end and AI or LE heads should make you very happy...
Matt
You don't have the budget for a properly built stroker
About A comp cams 280xfi is it too little for afr or ai heads.
You would be surprised how strong the stock crank is so that may be an option too so that you can save money and not have to buy a complete rotating assembly...
For what its worth.....We had a set of Eagle SIR rods in a 383 Solid Roller motor that made well over 400hp through a TH400 with unlocked converter and a 12 bolt with 4.10 gears.... We were also spraying it out the hole with a 250 shot...turning 7000 rpms...
the guy that had it before us was spraying it with a 2 stage 400 shot through a 6 speed...
The motor is still running to this day getting abused weekly....motor is at least 5yrs old.....
now I am not saying that SIR are the best thing out there I am just giving a PERSONAL experience want to clear that up before I start getting bashed...
