New PB LE2 383
QA1 12 ways on all four corners
air bag in the RR spring
Removed front sway bar
BMR adj tq Arm swet at -2.5
BMR transmission crossmember for tq arm relocation set three holes from the top with stock ride height
The tires probably are whats holding me back at the moment. Being 6-7 years old and having TONS of passes on them Im sure they're about wore out (even tho treads good)
FYI the car only dyno'd at 388rwhp 381rwtq unlocked on a dynojet...
I used to think off idle but at the LTX shootout I was trying different things and it sixty best with a load on it. Also I would not have your converter reflashed if your going to spray it, 3600 is a good size for spray and I would go 4000 + if your going to stay on motor.
