Underdrive pully low voltage
Ok so I put the system on at 1st put both the crank and Alt pully on with a very low output of voltage. So I just put the crank pully on. Better but still the same output. So I thought maybe my Alt was **** so i changed it...well a week later I fried it and just put my stock system back on. I miss it!! Has anyone else had this problem and this is normal or am I missing something?
Right but wouldnt it make it make faster? I thought the idea was to slow down the ALT so it dont fry but instead it slowed it down to much. The only other thing im running is a 12 and a 250w amp. Other kits I've seen just had the crank pully. Maybe the type or size could be thee issue maybe? Or belt isnt the right size? Both pullys ran a 60 inch just the crank 59.25'
Village Troll ![](http://jameskellock.tripod.com/sitebuildercontent/sitebuilderpictures/rsman.jpg)
March claims their O/D pulley turns 15% faster than stock when the U/D-O/D pulley are used together.
No. The alternator has a regulator so it will not fry. There are other accessories to take into consideration than just the alt. However IMO you did the right thing by taking them off. Stock is just fine unless you are trying to eek out 1hp here and there...
