Question for those who did LTTC/Delteq mod to lt1
I was thinking about converting my 95 camaro z28 lt1 to indivual coil's like the ls1 style -- the deteq or LTTC mod I beleive it's called. Anyways is it a direct plug in play type deal... Cause I have a 383 stroker with a supercharger... Would I need to have a re-tune done again??? Also I'm currently running a crane fire ignition box -- does that get removed also?? or will that work with the coils??
I can't say anything about the LTTC since I don't have any experience with it. But I'm not a fan of the Delteq systems. My experience may not be accurate though because I ended up doing a rebuild based on all my problems. I also know a guy with an LT1 Vette though who is now going back to a stock type ignition after fighting with his Delteq for 2 years.
My problem with them is there are so few people running them that if there is a problem nobody knows how to help. No one has spare parts laying around to troubleshoot. I felt very alone when I started having trouble. With the stock system, when I have a problem, there are a dozen people who know what I'm talking about and have ideas/parts to help with.
Trust me please. Stick with the optispark. If you get a good replacement ( not sure if ms ones are good ) they will last a long time and they're easy to swap. The ltcc looks ugly to me, it's expensive and does Nothing at all power wise. There are probably hundreds of 400+rwhp ltxs out there with a stock or gm opti.
I ditched mine for a rear distributor only because I'm running a gen7 DFI ECM and am spinning 8000 rpms. If i didn't go high rpm I would have stuck with a vented gm opti.
