moroso oil pan, trans lines
put moroso oil pan on my 383 lt1 and the trans lines do not line up to trans fittings because of oil pan kick out on pass side. also if i bend lines starter removal will be very hard. could i just splice in a section on rubber trans hose in this area to make future repairs much easier.
run all new lines. i would recommend braided line but you can also check out pushlok. not sure of your setup but i hope if you have a higher stall converter, you also have an aftermarket trans cooler. don't use rubber line clamped to metal line, it will leak and possibly blow off.
