160 thermostat?
The stock temp for closed loop is ~140°, so it that's not going to happen. Normal operating temp is generally going to be 15°-20° higher than the thermostat temp on a moderate ambient temperature day. If you are in a cold winter climate, you might want to keep the 180° for the winter. Temps will stay closer to the thermostat rating when it is really cold out.
