block strength
Old Feb 7, 2011 | 02:15 PM
AChotrod's Avatar
I would also go with splayed or 4bolt caps, actually I am going with splayed caps, and a half fill on mine. If you do get splayed caps get the 10* ones.
Old Feb 7, 2011 | 02:37 PM
quik95lt1's Avatar
keep in mind rpm is a big factor in crank/ rod and block strength as well.......rpm can be a killer
Old Feb 7, 2011 | 04:51 PM
brngrhd's Avatar
it may not be making that much power either it was a guess based off other builds
Old Feb 7, 2011 | 08:23 PM
brngrhd's Avatar
FWIW I'm talking flywheel numbers not wheel numbers
Old Feb 7, 2011 | 08:25 PM
96capricemgr's Avatar
What you will find on these forums is everyone who guesses at power seems to identify the best "similar" setup to theirs and then add like 10% to make a guess at theirs, then a lot of folks keep posting that stuff and someone else does the same thing based off of that guess. Pretty soon bolton cars are making 350rwhp and a mild stroker makes at least 475rwhp.
Seeing as you are able to admit your's is a guess and it might not hit that suggests you have your head on straighter than most, which will go a long ways towards making it all work out.
Old Feb 8, 2011 | 05:42 PM
brngrhd's Avatar
another thing i don't like about talking numbers is WHP and CHP getting mixed in the same conversation. My last build was a BBC that had small cam low compression and made 580hp at the crank put it in the car and it made 409 on a dyno jet changed carb and intake went to a mustang dyno and made 370 LOL this was all through a 3500 PTC converter throught TH400 and a nine inch. my buddy has a cobra that made 460WHP and i'd walk him from a dig from a roll no matter how you sliced it.
so the numbers are not really important to me it is more getting what i got to make the best number and stay together. the reason for the 600hp guess is simply that a guess based off a 13:1 383 with good heads and good cam.
Old Feb 9, 2011 | 01:29 AM
93Z2871805's Avatar
Veteran: Air Force
What car is this motor going in, the Nova in your avatar?
Old Feb 9, 2011 | 02:48 PM
brngrhd's Avatar
yes
Old Feb 13, 2011 | 09:39 AM
brngrhd's Avatar
so what are your thoughts? will it handle this plus a 100shot or leave the nitrous off?
