LT1 383 Blower Build
Old Dec 13, 2010 | 08:15 PM
  #61
Blackbirdws6's Avatar
Originally Posted by Rumblin70ss
Looks great! Good luck with getting it together!
Who did the machine work on the block?
Thanks!
Fonse Performance in S. Jersey did the work. They have done machine work on LT1's before that were prepped for a 383 and came well recommended.
More pics.
Installed:
ARP head studs
Trick Flow Heads
Cometic MLS Head Gaskets
Cloyes double roller timing set
Blower Cam
EFI Connection 24x cam and crank reluctor
TPIS Timing Cover
Moroso pan - just thrown on for looks/cover the bottom end.
Old Dec 13, 2010 | 08:22 PM
  #62
marc97taws6's Avatar
Looks great! Can't wait to see it running
Old Dec 14, 2010 | 05:27 AM
  #63
LT1's Avatar
LT1
Originally Posted by Blackbirdws6
Awesome build, good to see lots of pictures.
In this picture are you checking deck height to determine the compression ratio?
Old Dec 14, 2010 | 05:58 AM
  #64
Thanks! In the picture I was making sure I was at absolute TDC before I threw the cam in. I wanted to make sure the dots on the timing set lined up accordingly.
Old Dec 14, 2010 | 08:57 AM
  #65
95mysticta's Avatar
Very nice setup and more pictures!
Old Dec 14, 2010 | 03:29 PM
  #66
qc97z's Avatar
Looking great Brian. I almost wish I built my motor instead of bought it outright. It would have been a lot more expensive, but I would have gotten to experience the awesome feeling of taking those pics of brand new bling.
Old Dec 14, 2010 | 04:55 PM
  #67
Waiting on a few bolts in the mail to finish up a few things but otherwise the engine is almost done. I'm a little bit nervous to bolt on the blower with the engine stand wobbling with all the weight now LOL.
Nothing wrong with buying it outright and hopefully mine will run as good as yours. Like a new born, all I want is for it to be healthy...and wouldn't mind it throwing down some decent power too
I am taking a lot of pics because sadly, you (hopefully) won't see this stuff once its all covered up.
Old Dec 15, 2010 | 01:26 AM
  #68
LilJayV10's Avatar
Looks great man. Can't wait to see more.
Old Dec 15, 2010 | 09:44 PM
  #69
drivelikeIstoleit's Avatar
where'd you guys find your LT1 F-1A s/c kits and how much were they? All I can seem to find from ati are the d1sc and p1sc versions, whereas your guys' F1s sound way better.
Old Dec 16, 2010 | 05:05 AM
  #70
I got mine from Bob @ Brutespeed. He is a sponsor here and gave me a great price. The F1A head unit is an upgrade option on the D1 kit but not always listed explicitly that way.
Old Dec 16, 2010 | 04:34 PM
  #71
qc97z's Avatar
To source an F series from ATI, you need to specify it. It's sort of a custom-order thing.
I would advise using the SDCE tensioner kit with it, I think it's also available from Brutespeed.
They seem to be swallowing all of the Procharger business around here. I haven't heard anything negative about them yet.
I bought my kit complete (sort of) from a member on here. Everything was right and was there except for the charge pipes, but I had those re-done and tucked up nicely and powdercoated!
In short, contact Bob@Brutespeed for more info.
And if you're not going for huge numbers (650+ at the wheels) an F-series procharger isn't necessary. There are a couple people with D series units making big power (Call911, and a couple others I think).
I could make more power with a bigger cam and a smaller pulley (~725-750), but I over-engineered my build so nothing is being maxed out (I'm an engineer, go figure). Procharger and valvetrain aren't being over-worked or pushed to the limit, so I can basically beat on it as hard as I want to and not worry about breaking anything.
Old Jan 5, 2011 | 07:53 PM
  #72
Well need some help guys.
First, the damper/hub install tool I rented from Advance Auto isn't going to work. This is the one I grabbed.
http://shop.advanceautoparts.com/web...%7CGRP2083____
Does anyone know the tool to allow me to press the crank hub onto the snout of the crank?
To make things more difficult, Callies decided to start the threads deeper into the crank snout so I need a longer 7/16 fine thread rod to ?? thread adapter to even think about using this tool. I will be calling Callies tomorrow to see what they recommend.
I didn't think of this before but I also don't know how the bolt in the center will even secure the crank hub when installed. See the pic below compared to the old crank hub. Its clear the old crank hub is smaller in the center to allow the bolt to actually do something.
Summit sent me the wrong pushrods (Comp Hi-Tech pushrods) which were 7.1" not 7.2". The box listed the correct length but the rods said something different. Summit was really good. I called them and they are sending new ones out immediately and only need me to send the old ones back when the new package arrives.
Now, onto what I did get done...not much granted the other issues I ran into. I got the new white spring installed in the Melling Select oil pump. Pump was primed, installed and the stud torqued to spec.
Also installed my lokar dipstick which required trimming of the shroud going into the block. The shroud hit the splayed main cap so I simply cut off the necessary length and its all good now. The lokar stick is a much more rigid piece than a stock flimsy unit so I don't imagine I will run into issues.
My other crafty idea actually seems to be working out. The polished elbow going into the throttle body has a fitting for the IAT sensor. The MAF is a 5-wire which has the IAT built in. Since I didn't need the fitting in the elbow, I converted it to be a port for the meth injection. The port was threaded too large to simply drill and re-tap the hole so I found a nice Russell 1/8NPT to 3/8NPT to hopefully make it work. I got the proper drill and tap for the 3/8NPT and successfully got the fitting installed. Looks great and should work perfectly fine.
Old Jan 5, 2011 | 08:16 PM
  #73
Lonnies Performance's Avatar
LS1TECH Sponsor
You need to buy a standard small block Chevy Harmonic Balancer bolt. It has a large washer that holds the hub in place.
Do not buy cheap all-threaded rod to pull the balancer on, it is soft & will often break off in the crank. Grade 8 all-thread is not commonly available. I recommend an installer tool. They are rather cheap cosidering the problems caused when you break somehing off in the crank.
Old Jan 5, 2011 | 08:35 PM
  #74
robsquikz28's Avatar
why the bbc timing cover???
Old Jan 5, 2011 | 09:05 PM
  #75
Thanks Lonnie! I order all grade 8 stuff as I mentioned from McMaster so I can this thing on. I will call Callies tomorrow regarding the bolt as the standard small block bolt does not sound deep enough per the specs on Summit/ARP.
The new cover, besides looking pretty sweet, is clearanced for the big block crank hub.
Old Jan 6, 2011 | 10:52 AM
  #76
qc97z's Avatar
^ I can't remember if we touched on that on here or on LTXTech. The BBC crank hub is good for higher HP supercharger setups, more specifically, the F-series of ATI blowers. Especially if you're running a 12-rib setup. The LT1 crank snout and stock hub can be weak, and have snapped before. This is just a bit of extra engineering to ensure a long, healthy life.
Brian - As far as installing the ATI hub, You just need an SBC crank hub bolt with the big washer. I just had an ARP one that was brand new that I just sold...should have though about ya!
As far as the install tool...I ran into the same issue. I ended up using a fairly unorthodox "install tool" - a block of wood and a rubber mallet. I know I'll get slayed for saying that, but you know...if you know what you're doing and you're careful, it'll be fine. Can't tell you how many times my dad and I installed hubs on 900+HP BBC dragster motors like that.
Of course, getting a better tool is a better idea. But sometimes you gotta do what you gotta do.
Old Jan 6, 2011 | 04:48 PM
  #77
No worries Brett. The ARP bolt for a SBC won't work since its only a 1/4" longer than the LT1 bolt. I did a bunch of measuring this morning and gave Callies a call. They have stud kits in stock for their cranks made by ARP so I picked up one of them. Based on the measurements, which I triple checked and even made a diagram, I needed to go with a 6.400 stud with washer and 12-point nut.
As for a hub install tool, I'm going to make my own with all grade 8 hardware including a 7/16-20 1' threaded rod, nuts, and large thick washers. I will use the thrust bearing from the kit to press the hub on when I get everything setup.
Old Jan 7, 2011 | 08:18 AM
  #78
qc97z's Avatar
^ Psshh...you people and your "special tools". I like the hammer better
Sounds great Brian. Keep up the good work. I think I may just beat you to the punch though...I've only got a few more things to do and I'm ready for startup!
Old Jan 7, 2011 | 09:51 AM
  #79
Haha, yea fancy tools indeed. The machine shop that did the balancing on the rotating assembly took a little off the inside of the hub to make it easier to get on but its still going to be a tight fit.
You are way ahead of me but slacking on the pics.
Old Jan 7, 2011 | 10:02 AM
  #80
Keep the pictures coming
