Red Lock-tite on ARP rocker studs?
Old Nov 10, 2010 | 06:23 PM
Rob94hawk's Avatar
Default Red Lock-tite on ARP rocker studs?
When I put new guide plates on I noticed that the 7/16 rocker studs had red lock-tite on it with thread sealer. So I cleaned the threads off, put fresh thread sealant, and torqued them down to 70.
Should I have put fresh red lock-tite on it as well?
Old Nov 10, 2010 | 06:24 PM
gregrob's Avatar
GREEN, it must be GREENNNNN
Old Nov 10, 2010 | 07:28 PM
96capricemgr's Avatar
70ft.lbs on rocker studs???? I don't think so. Sealer only and about half that torque.
Old Nov 10, 2010 | 07:59 PM
Rob94hawk's Avatar
Well they were used so I wasn't sure if they came with lock tite new or it was put on afterwards.
Couldnt find the torque specs on ARP's website so I did a search and found people torque theirs to 70.
Old Nov 10, 2010 | 08:03 PM
suicidal racing's Avatar
studs are 35lbs if i remember right..head bolts are 70 with arp's lube or 80 with oil.
Old Nov 10, 2010 | 08:20 PM
speed_demon24's Avatar
That's too much torque.
Old Nov 10, 2010 | 08:24 PM
Rob94hawk's Avatar
That's not what I want to hear. I only did one head. Put the guide plates on then put ARP ultra thread lube too. Hope I didn't **** anything up.
Although it really wouldn't surprise me at the rate this build is going...
Old Nov 10, 2010 | 08:26 PM
That new ARP lube is seriously slick stuff. I sincerely hope you did not hurt the thread inserts.
As said above heads are up around 70ft.lbs, rocker studs are more like 35ft.lbs.
Old Nov 10, 2010 | 09:06 PM
Rob94hawk's Avatar
Everything looks good. Torqued them to 35. Gonna have to redo some of them since I don't like the way the guide plates are centered.
Old Nov 10, 2010 | 10:13 PM
robsquikz28's Avatar
Should use thread sealant to seal them in the heads especially if they are ported. They create a vacuum leak if they are not sealed completely off.
Old Nov 10, 2010 | 10:34 PM
Rob94hawk's Avatar
I noticed that so I put the sealant on pretty good.
Old Nov 10, 2010 | 11:25 PM
shbox's Avatar
Stock rocker stud torque is 50 lb. ft.
Old Nov 11, 2010 | 12:07 AM
Is that dry?
Old Nov 11, 2010 | 08:10 AM
whytryz28's Avatar
So 35ft lb for ARP studs? Im installing mine today thats why.
Old Nov 11, 2010 | 08:29 AM
SS RRR's Avatar
Village Troll
Do not use loc-tite on studs. Use sealant and torque them to factory spec.
Old Nov 11, 2010 | 10:21 AM
Rob94hawk's Avatar
Note to self: Google is not always your friend. Next time call the manufacturer.
Old Nov 11, 2010 | 10:45 AM
lt1-xjs's Avatar
As stated stock torque is 50. Most aftermarket heads say 55-60 and the ARP website says 70 for a 7/16 stud. As Rob94hawk says, call ARP and see exactly what they say and pass on this usefull tid bit to the fellow board members.
Old Nov 11, 2010 | 12:11 PM
Rob94hawk's Avatar
Originally Posted by lt1-xjs
the ARP website says 70 for a 7/16 stud. .
I did see this on their website before I did it the first time.
Old Nov 11, 2010 | 06:28 PM
lt1-xjs's Avatar
When I installed my ARP's, guide plates and Scorpion's I settled at 65 ft. lbs. That's coming up to almost 3 years now.
Old Nov 11, 2010 | 07:31 PM
whytryz28's Avatar
So you dip the studs in 30w oil before installing them?
