Build Ideas
Old Nov 12, 2010 | 10:14 PM
gregrob's Avatar
No forced induction. N/A for the road course, nitrous for drag racing.
Old Nov 12, 2010 | 10:15 PM
gregrob's Avatar
Originally Posted by AZZKIKR
Have you discussed your build with AIR? Might have some good idears for you.
Im sure
Old Nov 12, 2010 | 10:18 PM
pyro719's Avatar
Why not a nice turbo 355 making 600 hp @ Altitude?
Old Nov 12, 2010 | 10:20 PM
gregrob's Avatar
Cost, complexity, time, powerband.
I will do a FI build someday but dont have the time right now, and while I know you can do a turbo on a road course, it is simpler to keep in NA.
I dont need gobs and gobs of power. As FFB said, I'll have WAY more than enough HP to get into trouble on a road course when I do this stroker build.
And a nice little 200 shot for some low 10's
Old Nov 12, 2010 | 11:03 PM
pyro719's Avatar
Look Ma no bottle
http://www.youtube.com/watch?v=TU5cM7l8KBA
Old Nov 12, 2010 | 11:16 PM
gregrob's Avatar
and???
Old Nov 12, 2010 | 11:23 PM
pyro719's Avatar
Its just a 383 lt1 with a procharger
Old Nov 12, 2010 | 11:28 PM
gregrob's Avatar
Yep. Badass car.
Old Nov 13, 2010 | 03:40 AM
fex77k's Avatar
Originally Posted by gregrob
pistons: Open for recoms, i want them light, forged, etc obviously.
cp
ring pack. I dont know that i want to run a vacum pump for reliability purposes.
i wouldn't run a pump unless you really need that last few hp
oil pump: Stock with white spring.
ere uses the titan pump, which is pretty good for a wet sump system.
Valvetrain: Looking for suggestions, it will not be cheap. Might keep my comp ultra pro mags, or i can easily sell them and move up. Jesels, td shaft mounts, morel link bar lifters, etc.
definately jesel
cam: Will probably work with the head supplier and a good friend to spec the cam. Probably something in the low 240's intake duration with 540ish lift for valvetrain reliability purposes. Again, road race.
you need a bit more lift and durration for 500
tifwiw
Old Nov 13, 2010 | 04:21 AM
4K+Converter's Avatar
Do not agree
I will have an LSX but its not going in this car.
What about a BBC? Although a BBC isn't an option if your dead set in what class your going to run.
A friend of mine runs a crate 502 in a 69 Camaro, and I'm amazed at what cars that little motor pulls away from at the road race track. He kills most anything with exit speed coming out of corners.
A big cube, lower revving motor would drive like a ***** cat on the street and then spray the snot out of it at the strip.
Old Nov 14, 2010 | 01:00 AM
gregrob's Avatar
Originally Posted by fex77k
tifwiw
Thanks for the ideas Mark
  #32
gregrob's Avatar
Lol no BBC. I would like to build one someday, but it wont be going in my Camaro.
Old Nov 14, 2010 | 01:01 AM
  #33
gregrob's Avatar
Been discussing things a little bit with Mr. Ellwein.
Looks like this will end up being a 408
