gauge cluster
any 94-97 will work, but you gotta do some changes. In order for a 94+ to work you have to remove the tach filter near the coil, otherwise the tach won't work over about 2500 rpm. Also, if you use a 97 there are a couple of lights that you have to block off inside the cluster as they will remain on all the time (I want to say it is the seat belt and traction light, but don't recall for sure.
94 gauge cluster, all you have to do is remove that filter. One of the many quirks involved with having a 93!
