heater box??????
Old Nov 17, 2010 | 11:24 PM
fastredlt1's Avatar
Default heater box??????
thinking about removing the heater box, what is the best way to do this and will i have to take out the dash??????
Old Nov 17, 2010 | 11:36 PM
tricked94camaro's Avatar
but heat is your friend when your windows fog up.
Old Nov 18, 2010 | 09:54 AM
69gto96z's Avatar
Take a saw, cutoff wheel, or hammer to it. By the way, you can remove that box and keep your heat.
Old Nov 18, 2010 | 06:54 PM
sweetbmxrider's Avatar
1 or 2 bolts come in from the the dash side. pull the dash, its really simple.
Old Nov 18, 2010 | 08:35 PM
fastredlt1's Avatar
i thought by pulling that box that you lose the heat to???? Lets say i do cut it off, will that cover plate still work??? Anyone have any pics. Thanks guys
Old Nov 19, 2010 | 11:49 AM
search for a/c delete that retains heat. there are a few in the drag tech forum. you can cut the engine bay portion of the box where the evap core is and install the plate with some minor cutting to retain heat. your vacuum line and heater lines need to come through the plate. pm the merv too, he has a write up with a couple pics.
