need help on LT1 build
Regarding block, you could very well be able to use your existing "block" as foundation for your new build. However having a shop source you a good used LT block would probably only cost you a few hundred bucks and let you keep having fun with the existing motor while the new one is being built. The real cost will be the machine work involved with boring, squaring, honing, and machining for splayed main caps. But at least you'll have a foundation you'll never have to worry about.
Enough people out there seem to be pushing 450-500 hp with a studded 2-bolt bottom end without problems. I went the splayed route myself for piece of mind, but again if we're talking 500 flywheel/flexplate HP I think some people would argue its not terribly necessary.
Tubular K member
Tubular upper & lower A-arms
already had a Moroso strut tower brace
Front sway bar
Boxed sub frames
Extreme TQ arm kit
Extreme rear control arms
ajd chromemoly pandhard bar
Extreme rear sway bar
Think the only thing else might be a cage some day. I'm not goiing to be doing 5k launches though!
You could get all this same stuff from competitors like Spohn or UMI. Everybody seems to have compatible stuff. UMI (I think) supposedly has a better designed "double" K-member according to some people. I bought all my BMR stuff well over 2 years ago (maybe 3) and every single piece looked great. I'm sure each company makes good stuff.
