twisted wedge heads
and also, does anyone know what parts are specific to these heads, i.e. valves, springs or what?
Valves/pushrods should be standard SBC.
I do remember they both had to use custom length pushrods, and that you can only run xxx amount of lift before custom valve notches were required due to the different valve angles/placements with the "twisted wedge" chamber. If I remember correctly it wasn't much over .525" lift and 23X something @ .050" that was recomended. That was with a flat tappet hydraulic. I'm pretty sure all this would still apply to the LT1 since the differences should be water passage related only.
No one gives a **** if you think my comment was necessary or not.
Lloyd Elliott is really good at what he does and the price is better. I don't see why you have a reason for bashing him. Like he ports heads the wrong way just because they are hand ported!
