Wicked94Z first track outing....
Old Dec 7, 2010 | 12:10 PM
  #41
Wicked94Z's Avatar
Originally Posted by bowtienut
Nice results for the first outings, Wicked!
I'm guessing it has .3 to .4 more 1/8 mile ET in it, as well as 3-4 mph.
Congrats
Thanks! But you're running quicker in your boat lol
I'd really like a 6.60 out of this setup with the HR cam in there. I think if the nut turning wrenches can figure out how to get the suspension dialed in, it will go mid 1.3s on this gear and converter. I've got a local Stock racer I've been talking to, hopefully I can pick up some tricks from him Then comes solid roller and nitrous
Old Dec 7, 2010 | 12:21 PM
  #42
quik95lt1's Avatar
i agree with pat that things definatly got more on the table just as it sits......i cant wait to see it with a SR on spray!!!! congrats again man!!
Old Dec 7, 2010 | 12:31 PM
  #43
bowtienut's Avatar
I have no doubt you'll get there with the current engine setup. From the first runs on mine to where I am now, I've gone from 7.2's to 6.9's, and that's with a chassis that was already dialed in. You have more on the table to play with. When you really get it to hook, you'll go faster with quite a bit more air in those slicks.
Old Dec 7, 2010 | 12:32 PM
  #44
quik95lt1's Avatar
dont mean to hijack here but Pat what are u running in ur slicks for presssure???
Old Dec 7, 2010 | 12:37 PM
  #45
bowtienut's Avatar
I like to run about 16, but was all the way down to 13 at Cecil on Sat trying to compensate for the poor starting line. 16 might sound like quite a bit for a 30x10 tire, but it's needed for all the weight that gets thrown on it when it hooks.
Old Dec 7, 2010 | 12:41 PM
  #46
quik95lt1's Avatar
ive played with mine and its seems like anything over 13 and it wont hook......i been running 11.5-12 in mine and it hooks but i have noticed in pictures that the rim is really close to the ground becauase of all the flex in the sidewall....and also the low air makes it a bit wiggly down the track on the high end......id like to get more air in them.....and my tire is smaller than urs too im a 28x10
Old Dec 7, 2010 | 02:02 PM
  #47
stumprrp's Avatar
not to hijack either, but try those drag radials V.
Old Dec 7, 2010 | 03:05 PM
  #48
Wicked94Z's Avatar
Tubes or stiffwall at our weight! My **** skates all over the place and I'm only going 100 tops. It felt better with 12.5 just wouldn't hook worth a ****. I'll bet getting rid of that sidewall flex is worth a few hundredths in 60', plus it won't unload so much after the initial hit, plus R/T will be so much more consistent if you race brackets. Just think about how long the sidewall will last slamming the tire down like that... 40 passes maybe? The radials will be more hit and miss with the tracks here, but that's why i'm stepping up to the 29.5 to gain some rollout.
Old Dec 7, 2010 | 03:21 PM
  #49
AChotrod's Avatar
Not bad at all for the first couple times out! Its got way more in it.
Man I wish our season wasnt over. I never got to test out my new set up at the track. I can say on the street the Drag radials hook pretty damn good with the afco shocks out back. I would even say they work better than the QTPs I had on the car. I also had the same prob with the rim almost bouncing of the ground, the radials should solve that problem.
Old Dec 7, 2010 | 03:41 PM
  #50
quik95lt1's Avatar
maybe ill try a stiffwall next year........yea its definatly something u gotta get used to at 130+mph lol......espically if its a windy day
Old Jan 2, 2011 | 11:56 AM
  #51
SPRAYED Z's Avatar
anymore passes
Old Jan 2, 2011 | 12:58 PM
  #52
meine96ws6's Avatar
That car is a monster.
Old Jan 2, 2011 | 05:12 PM
  #53
s346k's Avatar
any idea what the car weighs?
the mph seems very low for a 13.5:1 389" motor.
gets off the line good.
Old Jan 2, 2011 | 05:18 PM
  #54
z_speedfreak's Avatar
awesome! congrats man, that thing moves and sounds evil!
Old Jan 2, 2011 | 05:51 PM
  #55
LTXBOI's Avatar
Got 4 passes in at the local 1/8 mile, these are my first passes with this new combo and overall I'm pretty pleased. I feel I have alot of improvements to make in this setup, both parts wise and tuning wise
Conservative tune, still 28* timing, IATs 115-120, A/F all over the place due to some datalogging issues my first 2 passes. Stock sway bar (no airbag), all stock front suspension, stock brakes all around, no SFC, no cage.
I didn't expect the 1.45 on the 3rd pass, and accidentally grabbed 2 gears in my panic that's why the brake lights, I thought I'd broken my shifter. Wish I hadn't fuxxed with the shock settings on the 4th pass!
http://www.youtube.com/watch?v=kHksW0Oh_JA
http://www.youtube.com/watch?v=pUjrPuWjkmc
yeah that thing really moves out hard!!!!!!keep us posted on setups,times,tech...
Old Jan 2, 2011 | 05:52 PM
  #56
gregrob's Avatar
Spray it
Old Jan 2, 2011 | 06:57 PM
  #57
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Originally Posted by SPRAYED Z
anymore passes
Agreed, the 16th has come and passed.
Old Jan 2, 2011 | 07:00 PM
  #58
robsquikz28's Avatar
anymore passes???
Old Jan 2, 2011 | 07:20 PM
  #59
ReggieWarrenJr's Avatar
Originally Posted by gregrob
Spray it
yeah what he said!!
Old Jan 3, 2011 | 09:52 AM
  #60
Wicked94Z's Avatar
No idea on the car weight... I'd say around 3300-3400 with me in it, I haven't cut anything on this car, door bars still in, etc. Yea the mph is low, but I have at least 2mph just in fluid changes, alignment, and shift point adjustment I only have 2 full 1/8 passes on the car, and 1 good datalog. There's alot left in the tune no question.
Spray it
That's what the motor was built for... I've got a .063 jet in it right now, just waiting on me putting the bottle back in the car. The converter is super loooose for this motor combo, needs an 8000 rpm capable valvetrain
