Question About headers
Old Dec 9, 2010 | 10:56 PM
MattSapp95_T/A's Avatar
Default Question About headers
I have hooker Long Tubes on my TA....
where the collectors bolt to the exhaust is bent on both sides and will not seal...
So I was thinking maybe I could cut the flanges an install and exhaust clamp would this have any problems sealing??
http://www.summitracing.com/parts/WLK-33279/?rtype=10
Old Dec 10, 2010 | 08:07 AM
SpeedDensityZ's Avatar
The only problem I see is that you would need a slip fit design with the y-pipe. I don't think the hooker y-pipe is designed that way. You would probably have to buy a different y-pipe or have yours modified to be slip fit, if they sell slip fit connectors. I use the Mr. Gasket Ultra seal gaskets and High Temp RTV and mine seals up fine but mine's not bent anywhere.
Old Dec 10, 2010 | 08:27 AM
pillarpod's Avatar
if there bent, i don't think it will help, just my .02
Old Dec 10, 2010 | 08:50 AM
the pipes themselves aren't bent just the flanges where the bolt together....that clamp is a butt clamp designed for butting 2 pipes up that are the same diameter.... so if i cut the y pipe off straight and the header off straight they would just butt up then that clamp should seal them right?
Does that make better sense?
Old Dec 10, 2010 | 09:46 AM
It may seal just fine then. I would have some exhaust mounting brakets welded near where the exhaust clamps together since it isn't a slip fit design. I see there being too much stress where it clamps together without brackets. You could try it that way first though and see how it works out.
Old Dec 10, 2010 | 10:52 AM
~BuMps AloT~'s Avatar
If it is going to be a butt joint they will seal just fine. That is the way I have my y pipe to cat back connected. I used a butt clamp from napa great piece imo
Old Dec 10, 2010 | 11:35 AM
Schweet97Z's Avatar
Do V bands and be done with it.
Old Dec 10, 2010 | 04:16 PM
ok I think that is what I will do..... Which ones are the V bands?
I don't think there will be much stress on it since the weld in cross member for my torque arm holds most of the weight.....
Old Dec 10, 2010 | 06:32 PM
robsquikz28's Avatar
I have flanges on everything and never look back. NO leaks and way easier for installs or removals...Hell I even made my LPPS into flange type
Old Dec 10, 2010 | 06:45 PM
Yea my buddy SpeedDensity has flanges and they don't leak at all......I have tried everything and they will NOT seal...Got under there and really got to looking and you can see where they are warped (or hit something) and that is where they are leaking from....So my only real option is to cut both flanges off flush and clamp it or have new flanges welded on.. I don't have anywhere local to do that so i would have to put it on a trailer and take it to the shop etc....
matt
Old Dec 10, 2010 | 08:18 PM
LT1's Avatar
LT1
Can you have the Y pipe open up wider by a half inch or so to slide over the header then put a clamp on it.
I used these clamps.
http://www.summitracing.com/parts/WL...5&autoview=sku
This how i have mine on the X pipe. Hasn't leaked had it for couple years.
Old Dec 10, 2010 | 08:21 PM
Lawhead's Avatar
My hookers do the same thing :/
but think its my X pipe set up thats bent thinking about heating it up and trying to knock it straight see if that works
Old Dec 10, 2010 | 09:52 PM
tricked94camaro's Avatar
i would do that. if that fails, what is plan B?
Old Dec 11, 2010 | 01:07 AM
Take it to an exhaust shop and have them fix it....no biggie...
I don't want to remove the Y pipe because it is a BITCH with my weld in cross member for my torque arm....
Old Dec 11, 2010 | 02:08 PM
Do it like that. I had one leak and i just took some aluminum foil and folded it over and over in about a 1 inch rectangle and put that around the exhaust pipe followed by the clamp. Sealed everything up nicely.
Old Dec 11, 2010 | 07:34 PM
1961ba427's Avatar
That's a good idea. I wish I had read this while my car was on a lift today. Was doing my first clutch install and would have been so easy to seal up the leaky Y pipe to I pipe connection.
Old Dec 11, 2010 | 08:17 PM
SoxXpupPeT's Avatar
Those clamps are much better then the other ones.. I have those on several cars with great success. If you were to cut off the 3 bolt flange. it should work fine. Just check the OD of the collector. If it is 3" then you can use 2 of those clamps to have them mate up to the Y/X pipe. IF its slightly bigger, then you can probably slip the 3" pipe into the collector and use another style band clamp. If thats the case then i Highly suggest these
http://www.summitracing.com/parts/PYE-HVC24/
