Deleting emissions stuff. Help!!!
Old Dec 19, 2010 | 03:28 PM
carlos64030's Avatar
Originally Posted by c_smalling
AA diagnosed my light with a OBD II scanner(?)
Upon reading the codes it was discovered that at least 1 of the pre cat O2 sensors were throwing codes. Now, it has been at least a year and I can't remember too many of the specifics.
I believe that you are saying that the codes have nothing to do with the air pump being gone., soo...
I just need to replace the offending o2 sensor(s) and I'll be good to go.
Wait... wuuuut?!?!?! An OBD II scanner on an OBD I car?
Old Dec 19, 2010 | 03:29 PM
nascarnate326's Avatar
Oh if a SES light is all that will happen, sounds great. Light is already on.
Old Dec 19, 2010 | 05:57 PM
c_smalling's Avatar
Default '96 Camaro
I didn't say it was an OBD I. Yes I get the SES light. Like I said, it has been quite awhile so I don't remember the exact code(s). I might just take it to AA tomorrow for fun, to get the code #'s. If a new O2 sensor will put the car back into closed loop then I'll try it.
Old Dec 30, 2010 | 09:59 PM
95zguy's Avatar
ok so i went to delete the evap and when i went to delete the purge solenoid { i guess thats what it is} everything went fine untill i unplugged the wire going to it. now i get a ses light. what now? am i doing something wrong?
Old Dec 30, 2010 | 10:37 PM
RamAir95TA's Avatar
You're deleting a critical emission component, so of course you'll set an SES light. You need to have it programmed out of the PCM.
Old Dec 30, 2010 | 11:45 PM
95zguy's Avatar
But until i get it tuned out it wont hurt anything to go ahead and delete it right? And it wont affect my performance?
Old Dec 30, 2010 | 11:48 PM
RamAir95TA's Avatar
It won't hurt anything performance-wise, but your cooling fans will be on all the time due to the SES.
Old Dec 30, 2010 | 11:58 PM
95zguy's Avatar
Yeah i noticed that when i unhooked it. Thats ok i can live with that. SO will it be ok to do the egr the same way? Delete it now and have it programmed out later?
Old Dec 31, 2010 | 12:07 AM
RamAir95TA's Avatar
Yes and no.
With the SES light on, you won't be able to tell if any other problems arise other than the EVAP and EGR. That's completely up to you, but I personally wouldn't want my SES light staring me in the face for no reason, especially if a code 16 popped up.
Old Dec 31, 2010 | 12:15 AM
95zguy's Avatar
Call me stupid lol but whats a code 16? And i guess i could leave the purge solenoid and the egr untill i swap in the 383. Was just trying to get some of this small stuff done before i do that. I still drive this car but only about 4 miles to work a couple times a week.
Old Dec 31, 2010 | 12:19 AM
RamAir95TA's Avatar
I only mentioned the code 16 as a worst-case scenario. It's for the loss of the low resolution pulse for the optispark, so if you set any other codes you'd have no idea because the light is on for the EGR and EVAP. Get it?
My suggestion is just leave both of them until you have the tune. Deleting them without a tune has no immediate benefit at this juncture.
Old Dec 31, 2010 | 12:34 AM
  #32
95zguy's Avatar
Yeah i got ya. I was just wondering what a code 16 was, knew it musta been bad the way you said it lol. Hope i never see it. Believe it or not this cars got 112000 on it the motor was rebuilt 9000 ago and still no problems with the opti. Ill just wait. I appreciate all the info THANKS.
