Deleting emissions stuff. Help!!!
Removing the EGR is easy - just remove the solenoid, valve, install blockoff plates (available from several site sponsors and eBay), and have it tuned out of the PCM.
The AIR system is also easily deleted. Remove the pump, lines, and check valves off of the manifolds, and install plugs. Assuming you have a 95, you'll need an M22 drain plug for the manifolds and a 5/8" vacuum cap for the intake ducting. Leave the fuse in the fusebox and tuning won't be required.
The EVAP system is fairly straightforward too. Obviously remove everything, including the lines, purge solenoid (on the passenger side of the intake manifold), plug the fitting on the throttle body, remove the charcoal canister behind the driver side rear wheel well. Take the line off of the canister (the one from the fuel tank) and install a small breather. You'll get a bit of a fuel smell from the rear of the car, but that's to be expected.
And good choice on those parts. I hear AI-headed 383s and Performabuilt transmissions work well together.
....good luck!!! Trending Topics
Remember these are for POST-CAT sensors, NOT pre-cat.
Please help me eliminate the codes. I have contacted PCM tuners about this and was told that they could program the PCM to not use the pre-cat sensor input. My mileage has dropped considerably since removing the air pump because it is running in the open loop mode
I hope to regain the pre-delete mileage by making a fix by whatever means.
The AIR pump and O2 codes are not related. When you delete the AIR pump (assuming you have an OBDII car) and the PCM calls for AIR pump operation, the PCM looks for the change in A/F ratio in closed loop via readings from the O2s.
What tuners are you contacting? I have a hard time believing any respected tuner would recommend tuning out the O2s in order to clear an AIR pump code.
Have the AIR pump code programmed out, fix your hacked O2 wiring, and install AC Delco 4-pin O2s.
Upon reading the codes it was discovered that at least 1 of the pre cat O2 sensors were throwing codes. Now, it has been at least a year and I can't remember too many of the specifics.
I believe that you are saying that the codes have nothing to do with the air pump being gone., soo...
I just need to replace the offending o2 sensor(s) and I'll be good to go.
Swap the passenger O2 with the driver O2 and see if the code follows the sensor. If it does it's a sensor/wiring issue. If it stays on that particular bank then you've got other issues to worry about.
