Crank hub
It seems like if someone hacked it up pretty good and the hole in the middle seems kinda oval instead of a circle. Wondering what i can do from here? I got another hub and pulley from a 95 Camaro and wondering if i can go that route?
What they did is put a gear puller in there, and proceeded to impact it until they started to bend the tabs. Then they finally realized that messed something up, and then used the above method.
Get a new hub, if you can wait a week and will pay shipping I have that spare one. The reason I don't need it is because I run a aftermarket crank with a keyway for my ATI superdamper. Actually I know LT1 Corvette crankshafts have a keyway in them from the factory, which I don't know why. Also inspect that crankshaft snout.
Doesn't matter either way.
