Blew a Headgasket.... NEED OPINIONS
Old Dec 19, 2010 | 11:20 PM
  #41
SpeedFreak123's Avatar
Originally Posted by WS Sick
Late to the thread, but did you turn the motor over with the heads off to make sure all the pistons cam up the same height? with water going through the cylinders its possible to bend a rod.
Yes i did turn the motor over.
Old Dec 19, 2010 | 11:50 PM
  #42
Scott_97's Avatar
I would do both now but you need to take your heads to a shop and have them checked out. it sounds like you might have a cracked head!
Old Dec 20, 2010 | 12:00 AM
  #43
I did do both heads.... I didnt have the time nor money to have them checked at a shop.
Old Dec 20, 2010 | 12:10 AM
  #44
badass383formula96's Avatar
did u use thread sealant on the stock reused head bolts!?!?!?!? if you want something to be reliable you take the time an the money an u get it done right. Im a broke *** bitch an i still send my **** to be checked.
Old Dec 20, 2010 | 12:13 AM
  #45
and were not trying to be dicks at all, most of us have been there done that. Were trying to get u in the direction to get it done right an make it last even till summer, in which from what u said doesn't look likely.
Old Dec 20, 2010 | 12:15 AM
  #46
RamAir95TA's Avatar
His silence should make it obvious that he didn't do half the things we suggested.
Old Dec 20, 2010 | 12:17 AM
  #47
which is plain *** ****** stupid!
Old Dec 20, 2010 | 12:19 AM
  #48
the 44 dollars he just wasted in head gaskets which will need to be replaced if not done right coulda went to a machine shop bill.
Old Dec 20, 2010 | 12:44 AM
  #49
I did it all wrong. Your all right. Thankyou for your replies, they were helpful, at least I'll know what to do next time.
