Blew a Headgasket.... NEED OPINIONS
Old Dec 16, 2010 | 08:03 PM
SpeedFreak123's Avatar
Default Blew a Headgasket.... NEED OPINIONS
I recently Blew a head gasket on my LT1. I tore the motor down a little got the intake ready to come off (aside from the EGR pipe in the BACK of the damn intake), valve covers off, spark plugs out, all wiring unplugged, Brackets blocking head bolts off, etc..
Now i have to disconnect the headers from the y pipe and drop the headers a little bit, so i can get to the head bolts. Drivers side will be easy (Driver side is the one thats blown).
My question is, should i do both or just driver side... I want to do both but here's the problem...
I have till Saturday to get my inspection done.
My car is outside on 4"x4" blocks.
Its 20 degrees out.
Theres 2" of snow on the ground.
Really need help here.
Thanks in advance,
Kyle
Old Dec 16, 2010 | 08:17 PM
Wesmanw02's Avatar
Thats really your own personal decision man.
Obviously its ideal to do both headgaskets at the same time. Whenever I do head gaskets on a V motor I always do both. If one blew, the other is probably not far behind.
You have to weigh out how much work it is to get to the point of actually being able to remove the head vs. the time you want to spend doing it now. If you don't mind doing it all over again from the start, then you could probably just wait until Spring to do the other side.
Old Dec 16, 2010 | 08:19 PM
93sspcoupe's Avatar
if its your only transportation i say do one, but if you got something else to drive daily then wait about it and do both gaskets at once. cause if one blew the other prolly will too, also have the heads checked out by a machine shop
Old Dec 16, 2010 | 08:21 PM
fergymoto's Avatar
Do them both while you're in it. Check the heads for cracks too. It is common. It might take you an extra two hours to do the other side too if you haven't done it before, which still isn't bad.
Old Dec 16, 2010 | 08:22 PM
RamAir95TA's Avatar
If the engine overheated at any point, you need to have the heads checked for straightness. Not just one, but both. No way would I just replace one gasket. You're looking at an extra two hours to pull and install the other head. Not worth the risk of just doing one.
Old Dec 16, 2010 | 08:29 PM
It is my only source of transportation.
Never overheated on me, Only got too 210 degrees at its highest point (I have a digital gauge and i was watching it like a hawk ) haha.
Yeah. I figured. I could do one, and my friend said he would replace the other for me in spring when its warm out for $300
Old Dec 16, 2010 | 08:34 PM
gregrob's Avatar
Do both.
Then spray it
Old Dec 16, 2010 | 08:56 PM
No spray for my DD. Haha. Maybe a LE custom grind tho
Old Dec 16, 2010 | 09:21 PM
badass383formula96's Avatar
do both now not later.
Old Dec 16, 2010 | 09:36 PM
Damn. I was hoping I'd get a few more laters than nows. any ideas on getting the headers apart from y pipe? There's some rust holding it on there? Heat it up maybe? Any suggestions?
Old Dec 16, 2010 | 09:48 PM
rubber mallet, maybe pb blaster? never had much of a issue with mine though.
Old Dec 16, 2010 | 09:49 PM
05HD's Avatar
Well, if you took the intake manifold off, you may as well go ahead and do both.
Inspection isn't the end of the world, if you are a few days late, you will live, unlike freezing to death trying to fix the car in the driveway.
Old Dec 16, 2010 | 11:00 PM
Well if I don't get it inspected, I have to pay for insurance on both tags. I still have tags from the old car so its cheaper to transfer them over
Old Dec 16, 2010 | 11:23 PM
camar0corey's Avatar
Do both. No way would I tear the car down that far and only do one!
Old Dec 17, 2010 | 08:07 AM
quik95lt1's Avatar
do both you already got it apart its not gonna take much to do it now.....
Old Dec 17, 2010 | 08:22 AM
moderate Z28's Avatar
Why did it blow?
Old Dec 17, 2010 | 08:29 AM
tricked94camaro's Avatar
do both.
Old Dec 17, 2010 | 09:29 AM
1961ba427's Avatar
Originally Posted by moderate Z28
Why did it blow?
What I was wondering too. OP said it never ran over 210* so....?
Old Dec 17, 2010 | 12:04 PM
I dont know why it blew.... I got the car, a little less than 2 weeks ago. It started saying "Low Coolant" on the dash, but i wasnt low on coolant, then white smoke started pouring out the tail pipes, every time i drove it/had it running, and it smelled really sweet. Then the motor wouldn't turn over, cause coolant got into my cylinder.
Old Dec 17, 2010 | 12:38 PM
draggin97s10's Avatar
do both it would be really stupid not too. **** if you do one it might blow the other on your test drive. how would that make you feel?
