dumb question probably... about egr
Old Dec 20, 2010 | 09:49 PM
Fish-man's Avatar
Default dumb question probably... about egr
I'm installing 'race' headers on my 95...can I leave the EGR valve and pipe in place, and simply block off the end of the pipe (where it would have hooked up to the oe exhaust manifold)?
I do plan on getting a tune to cut out the egr in the computer... but i'd rather leave the parts installed on the intake. For nothing else than it'll save me time and knuckle skin... since I know that will be a PITA... also makes it easier to go back to stock if the need ever arises.
Thanks
Old Dec 20, 2010 | 10:00 PM
SoxXpupPeT's Avatar
Yeah, as long as you block off everything properly there shouldnt be any problems.
Old Dec 20, 2010 | 11:48 PM
TheTransporter69's Avatar
its not that hard to work back there, just lay on your motor and reach in. If you do leave the pipe dangling though, it might bang around back there and make some noise.
Old Dec 21, 2010 | 08:05 AM
Fish-man's Avatar
thanks.
yeah, i'll have to fab up a plate for the pipe on the exhaust side... and have to wire tie it up out of the way.
Should I bother unhooking/plugging the vacuum line going to the valve as well?
Old Dec 21, 2010 | 08:45 AM
DAVE00's Avatar
Originally Posted by Fish-man
thanks.
If you leave the EGR in place then just leave the vacuum line and you'll be fine. If you remove the EGR solenoid then make sure to pull the vac line from the intake mani and plug the port with a vac cap.
Old Dec 21, 2010 | 08:47 AM
DAVE00's Avatar
thanks.
Just go on ebay and pick a set of all three (egr solenoid, pipe - mani side, and pipe header side) for very cheap and then you can get rid of all that stuff in your bay.
Old Dec 21, 2010 | 12:03 PM
Fish-man's Avatar
still considering that. my thought right now is that it will be more trouble than its worth
Old Dec 21, 2010 | 12:18 PM
DAVE00's Avatar
WHY? Removing all EGR stuff, caping vac port and bolting up my EGR block off plates literally took me 10 mins. Wish the rest of my header swap was that easy.
Old Dec 21, 2010 | 12:28 PM
Fish-man's Avatar
10 mins?
i've read some peoples headeer install stories, and they made it sound like it took forever and was one of the more difficult parts of it... can't see... yadda yadda
Old Dec 21, 2010 | 12:30 PM
DAVE00's Avatar
10 mins?
For me EGR removal and blockoff plate install was the easiest - hands down!! 4 bolts - 5 including pipe connection on header and ur done. I'll agree that one of the bolts on the EGR solenoid is a bit of a pain to get to, but not hard at all.
Old Dec 21, 2010 | 01:00 PM
RamAir95TA's Avatar
If you have even an inkling of experience working with hand tools in general, it's a 20 minute job.
www.shbox.com has all the diagrams too. Familiarizing yourself with the location of all of the components before you get started is a good idea.
Old Dec 21, 2010 | 10:08 PM
ebeard's Avatar
^^ What they said. Get rid of it. Don't forget to cap the vacum ports. SHBOX!
Old Dec 22, 2010 | 03:59 PM
defaultexistence's Avatar
sell your car quickly or shut up and get to work, dumb idea of yours will take longer than getting rid of all that bullshit
