LT1 cam gear
Old Feb 7, 2004 | 06:37 PM
fastta's Avatar
Default LT1 cam gear
If an electric water pump is used on an LT1 and the water pump driveshaft/gear are removed, can a standard SBC cam gear without the teeth for driving the stock water pump be used?
Old Feb 7, 2004 | 10:44 PM
wrencher's Avatar
wrencher
Still need the drive in the cam gear for the opti, so no.
Old Feb 7, 2004 | 11:40 PM
fastta's Avatar
The optispark is driven directly by the camshaft drive pin not the cam sprocket itself.
Old Feb 7, 2004 | 11:50 PM
wrencher's Avatar
wrencher
Ya I was stuck on non-vented.....
So in this case I wouldn't see why not, ask cloyes or the like?
Old Feb 8, 2004 | 02:57 AM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
You can do that, but it has to be a timing gear for a factory roller camshaft. I prefer the GM single roller HD chain kit that the ZZ4 crate engines came with, I can get you a part number if you need it.
Old Feb 8, 2004 | 03:12 AM
66ImpalaLT1's Avatar
People have been doing this for years. If you have a 95+ optispark you can use a Cloyes made for TPI engines.
The hardest part is finding a plug for the timing cover. I gave up looking and siliconed a coin over it. It never leaked.
Old Feb 8, 2004 | 03:22 AM
-Joseph-'s Avatar
Ugh... How much did that mod cost you? I was thinking of having the hole in the next one I do welded up.
Old Feb 8, 2004 | 11:49 AM
fastta's Avatar
Pressing a brass freeze plug in works really well.
Thanks for the replies guys!
Joseph a part number would be excellent
Old Feb 8, 2004 | 12:07 PM
-Joseph-'s Avatar
The chain I normally run is a 12371043, it comes with the crank and cam gears, and the single roller chain. I think it was about $50-60 from GM. This setup is the same components as the "Extreme Duty LT1/LT4" timing chain kit, but you can only use it with an elec water pump since the water pump drive is not included.
Old Feb 8, 2004 | 02:29 PM
fastta's Avatar
Thanks Joseph.
Old Feb 8, 2004 | 02:54 PM
Camaroholic's Avatar
Don't use a CompCams double roller timing chain for a hydraulic roller cam. They suck.
Were I to do it over again, I'd use a Cloyes. More expensive, but less likely to have that happen. My poor LT1... Something with a solid center section.
I also used a quarter jbwelded in to the hole. Worked great.
Old Feb 9, 2004 | 12:00 AM
fastta's Avatar
ouch!
Old Feb 9, 2004 | 02:33 PM
License2Ill's Avatar
I run this setup with a cloyes works great. Nothing tops the old school double-row timing chains nothing well for the price that is!! Sorry I don't have a part number. But I have a place you can order it from for like 50 bucks. Let me know and I'll get you the numbers.
