Fuel pump install question!!!???
Old Feb 8, 2004 | 02:21 PM
gearhead69's Avatar
Default Fuel pump install question!!!???
I need to know about a fuel pump install by not droping the tank, and going through the top of the rear wheel well. My friend did it on his 94' LT1 camaro z28 and it worked on his, but I need to know if the location is in the same spot???
96' WS-6
Hurst Short Throw shifter
Thunder Racing WS-6 engraved ****
LT-4 Clutch
BFG G-force T/A KDW 275/40/17 front, 285/40/17
Jet-Hot ceramic coated 1 3/4'' long tube headers with custom SRS madrel bent 3" exhaust with 12" x 4" tips
No Emissions
Power-Slot cross drilled rotors
Manual fan switch
K&N filter
52mm Motorsport Technologies throttle body
Old Feb 8, 2004 | 02:39 PM
lt4malibu's Avatar
id just drop the tank rather than cutting into the car itself, but if you dont have access to a lift, you gotta do what you gotta do i guess
Old Feb 8, 2004 | 09:26 PM
snksknr94's Avatar
I would drop the tank. I'm not a fan of shooting sparks and pieces of hot metal right on top of the fuel tank. Plus there are a lot of fuel vapors outside the tank in the same area, it's an explosion or fire waiting to happen.
Old Feb 8, 2004 | 10:08 PM
Vendetta's Avatar
Agreed... be safe. drop the tank. Don't skimp or take any chances with your baby or your life.
Old Feb 9, 2004 | 11:11 AM
TN94Z's Avatar
I dropped the tank on mine and it only took like 2 hours to complete and that includes test drive. I wasn't a big fan of all those sparks around the fuel tank either. I would drop the rear, it's not that hard.
