Hey, any HR guys spinning well past 7500rpms
#45
Excellent combination of parts and definitely NOT your typical HR type build with that spring... LOL my solid roller setup is built around the 1243, ~.750 lift but...
I'm sure 7500 is doable with ~160 on the seat and 380-400 open if you keep the valve side mass low. I'd stay with a solid stem 5/16 valve if you don't want to spring for hollow 11/32 stuff, titanium retainer on a light beehive and you're there. Cheaper than your average SR setup for sure, but those heavy lifters are going to kill valvesprings if you want to push lobe intensity
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#47
Im not the only 1 doubting you and I have a mallory in my car as well and I was running nitrous too. It never mattered what I set my box to as for rpm limit, the pcm still did what it wanted. I have never seen the box over ride a pcm????? Maybe im wrong and have been doing this for years and maybe my pcm was junk
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
Either way I want to see your car on the dyno or even track
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
#49
I'm sure 7500 is doable with ~160 on the seat and 380-400 open if you keep the valve side mass low. I'd stay with a solid stem 5/16 valve if you don't want to spring for hollow 11/32 stuff, titanium retainer on a light beehive and you're there. Cheaper than your average SR setup for sure, but those heavy lifters are going to kill valvesprings if you want to push lobe intensity![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
I cannot find ANY info on the PAC-1243s besides a quick mention in a speedtalk thread and an ordering page that only lists the OD. Their site does not even find them in a search(?). How long have you been running them, and have they been measured again to check fatigue?
If they can reliably handle high rpm builds with .750+ lift and are sub-$300 they would be exactly what i need to replace my 943s(which won't handle the lift of the cam me and Llyod are thinking about).
It looks like they are 240# @ 1.9, with coil bind @ 1.100, but if you have their closed #s and rate/in it would be great...
::EDIT:: Found a page with a bit more info from some random website. "PAC1243 240@1.900 625@1.200 1.100 Coil Bind". Being circle track springs, how would they hold up to street duty and repeated heat cycling?
Apologies for the slightly OT, this thread is all over the place but hopefully its info someone else may need.
#52
I think the PAC-1243s would work spec wise, but they seem a bit cheap @ sub-$250 and I am worried about their reliability in a car that sees street duty.
#53
Okay I have 1 set that is brand new and is suppose to be good to .750 lift. I bought them with a set of heads and thats what I was told. If you have access to a machine shop and install them at 1.9 ht you can check them and see if they are good. They were installed at a 1.95 ht originally. I can send you one of them complete and you can shim/ check them for pressures and all if you want??? lmk
#54
Not concerned with the cam questions as I am going solid roller, but I would llike for someone to explain how I can get my OBD2 to rev past 7000. Not being a smart ___, just need more info.
#55
Those 20 grams saved are the equivalent of a hollow stem valve ($$$) but you can still run a solid stem severe duty and run the same rpm. On an 8000 rpm motor, every 10 grams you can take out of the valve side is 300 rpm or so. From the folks I've talked to that run the 1243, valve spring life is better and more consistant than their lifters! I'm giving away alot of my secrets here
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
