Guide me in my cam swap
I wouldnt attempt it by myself, still doing the basic take apart/put back together before i try machine work.
Ok so i guess on my way home from school ill stop at a machine shop and check to see what it costs to have them milled. Also at that rate I take it id have to order different pushrods than the 7.2's due to milling/thinner gaskets?
Best thing is spend the $15 and get a length checker. I have a brand new one FS. PM me if you want.
I'd say no. The amount of boost you can safely run will net you cam only hp. With a few other things you can raise it up to heads/cam power range, but you are running the ragged edge of safe for the bottom end at that point. Whereas a h/c car could do it safely and reliably.
book marking. i will need this soon aswell.
i plan on getting a custom cam from AI or that cam mentioned above 232/.. something. id say get the good stuff and not cheap out. in the end you will be happy. i didnt know this about the thiner impala head gasket and i just replaced head gaskets with felpro ones on my camaro -_-
good luck with your build.
Ok so ive done a bit of revising and such, hoping to get some more input here
LE cam ? Thinking the 224/230 or 226/232?
Rockers 324.95 1605-16
Pushrods 86.95 TFS-21407200
Studs 42.65 134-7103 (ARP 7/16th)
Guide Plates 25.95 TFS-30400623-8
Intake Gaskets 28.99
Front Cover Gaskets 15.95
Spring kit 226.95 10308-1 (crane double kit?)
Lifters 129.95 12499225 (GM lifters?)
Timing Chain 15.99
Anyone know if LE sells his cams alone, and about what they run? Anything i seem to be missing?
Timing Chain 15.99
The 224/230 LE cam should be fantastic, my car isn't a total DD so I ended up with a 306, I'll see if I needed to go smaller
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
