Starter spins super slow and won't start car
Something is causing voltage drop, something is putting a load on your battery besides the starter motor when you try to start the car. Next thing I would do would be start replacing cables, starting with the least expensive.
It looks to me (and others) that the starter is too close to the flywheel/flexplate.
OP, have you shimmed the starter out yet?
But I can tell you that if a cable is in bad condition, but still conducts electricity, even though a fluke meter shows low resistance it will absolutely cause excess voltage drop under heavy load.
The starter motor is drawing a lot of amps. This shows the battery and all the connections are good.
Take a handheld drill. Run it free. It doesn't draw that much power (current). Now grap it's chuck and try to slow it down. Now it'll draw more current through it's power cord.
Ohm's law at work.
The OP already said he’s checked his cables and connections and they’re good.
The higher the resistance a circuit is, the less current it will draw. Bad/poor connections would cause higher resistance and the battery’s voltage would not be drawn that low.
The OP’s starter is drawing so much current that’s it’s pulling the battery’s voltage lower than normal. Where is all this current going? Into the starter motor as it’s struggling to turn the engine over. If somehow all this current would magically be getting absorbed by the cables or connections, there would be clear signs of it.
This really is very simple guys. The starter needs to be shimmed away a bit. It’s not an electrical issue.
Time for za355tx to step back in here and let us know where he is with troubleshooting this.
za355tx, this is what i think you should do as your next step in trouble shooting.
If you've got any way to measure your current flow while trying to start the car that would help a ton. If you're getting excess current flow, than most likely Paul's idea that your starter is shimmed too close to your flywheel, causing your starter motor to work too hard is true.
If your cranking amps are normal, but youre still getting excess voltage drop, than you've definately got a bad cable, or maybe a bad contactor on your starter relay, basically something electrical.
I say this because if a wire is damaged, (for example if a decent chunk is somehow accidently taken out of your starter motor wires), if you try to measure resistance through it, the resistance will likely still be very low, just as low as it was before it was damaged. However, now when this said wire is trying to carry a big load, you'll see excess voltage drop without an increase or decrease of normal current flow.
This is something a bit more complicated than ohm's low, and jaycenk, I wish you would try to wrap your head around this before telling me that my information is incorrect, because I know that it's not. Go ahead and disagree with my theory on what's causing the problem, but do not tell me that my information to back it up is incorrect. I do electrical work for a living, this is nothing new to me.
I'm not thinking it has anything to do with the spacing or shims because the problem actually happened before the starter went bad. Basically we replaced the starter but it has the exact same symptoms as before. All the sudden one day it started spinning slow and did not start...so we replaced the starter thinking it was the issue and the car did the same thing. So that leads me to believe that whatever the problem is...happened before I put a new starter on. I've never had to shim a starter though or have one too close to the flexplate but why would that cause a power drop?
So the wires can be bad even if we tested resistance and everything checked out? Should I just replace all the wires? Ground and all?
I’m thinking the issue is mechanical. Are the starter bolts all good? Any chance that the starter is twisting while cranking?
Can you turn the engine by hand with a breaker bar on the balancer bolt?
Does this engine start at all? Have you tried shimming the starter yet?
Can't remember if our motors even have one, but have you tried swapping in a new starter relay? Never had to look for it on the LT1, but I know there's cars out there that don't have starter relays at all.
Hopefully there's nothing wrong with your motor.
That type of starter doesn't have a dedicated ground cable, it grounds by physical contact to the block; And then the engine block has a ground wire to chassis or battery.
It's easiest to think of the system as three things:
- Battery (the power supply)
- Starter (user of power supply)
- Losses. These are all the cables, connections, engine block, chassis, grounds, etc, etc that make up the electrical circuit between starter and battery. They all add up to some total resistance.
- If the battery is at 10V during the crank, then the maximum voltage the starter can see is 10V of course.
- If the B+ cable has a 2V loss, then the starter will see only 8V across itself. That's intuitive to most people.
- If the Ground side has a 2V loss, then the starter will see only 8V across itself. That's not so intuitive to some people.
- Combining those concepts, if the B+ and Ground each have 2V loss, then that's a total loss of 4V and the starter will see only 6V across itself.
That's really all you need to know. You can stop reading here and be able to figure out what's going on. If you want to get a little deeper then read on....
The battery is the power supply to the starter motor. The way a battery behaves is the battery voltage goes down as the discharge current increases. In other words, the more current the starter draws the lower the measured voltage across the battery.
Now the really important thing to understand about the nature of the starter is that the current goes up when the starter spins slower, and the current goes down when the starter spins faster. It's the nature of the beast and I don't want to explain why.
- What makes a starter spin slower? (1) Lower voltage across the starter; or (2) turning against a bigger load (more torque).
- And what happens when a starter slows down? Motor current goes up.
- And what happens to battery voltage when current goes up? Battery voltage goes down.
Lastly, what most people don't realize is that low batteries can still provide a shitload of current. So when a starter cranks on a low battery the starter spins really slow, motor current goes sky high, and the "weak" battery dumps a huge amount of current into the starter and the starter burns. And if the solenoid chatters it will literally turn the copper contacts into a molten mess. Never ever crank on a low battery. Never.
The car is a 94 formula. It was running fine and then the battery crapped out. So I got a replacement and then the starter would not spin the motor very fast. So I bought a new starter. The problem persisted. I put a starter from a currently running and driving F-body to see if I got a bad starter but it still would not spin very fast.
It's got plenty of oil, I ran a new cable from the battery to the starter. The new one being about twice the size of the old one...problem persists.
I cleaned all the grounds and reattached them and still nothing.
I checked the voltage of the bad car at the battery and it read 12.3 volts, then while cranking it read 8.3 volts at the battery. So then I tested the power at the starter itself and it was the same it only read 8.3 while trying to start. I did the same test on the good car and it only dropped to 11.5.
The battery also has new terminal posts and I cleaned all the connections too.
So it's losing voltage once I try to crank the car but I have no idea why. I've tried everything I can think of and still can't figure it out. I checked to see if the car was grounded well and it is. I did a resistance test from the battery to the motor and there was almost no resistance. I have no idea what to do and I really don't want to have to take it anywhere.
What could cause this problem and is there something I've missed? I've checked everything I personally can think of that would cause a starter to spin slow. Thanks a bunch in advance guys. I'm super stumped and it's starting to tick me off something fierce.
Zach
Zach
