10 bolt
Old Jan 8, 2011 | 11:53 AM
tricked94camaro's Avatar
Default 10 bolt
so im a noob when it comes to rears. what i want to do is beef up my stock 10 bolt for the street stock class for the shootout. my problem is it was bolted up to a 3.4 and has 1 tire fire. i want to make it posi but keep it as stock as possible. what can i do to achieve this? and i will need it to stand up to 300hp.
Old Jan 8, 2011 | 12:15 PM
Badazz 97 TA's Avatar
find a z28 or trans am model f-body at a junkyard or search the "for sale" midwest section and just swap rears. thats prolly the easiest way.
Old Jan 8, 2011 | 12:19 PM
where in wi are u from?
RamAir95TA's Avatar
By far your cheapest option is to pick up a take-out rear.
Old Jan 8, 2011 | 12:24 PM
will a 98-02 rear bolt on?
Old Jan 8, 2011 | 12:46 PM
any 93-02 will work. the only difference is the 3 and 4 channel rear. you need to find a 3 channel(a car without the traction control.) it will have a thing on top of the pumpkin where a 4 channel has a sensor for each wheel.
from waukesha btw.
Old Jan 8, 2011 | 12:50 PM
RamAir95TA's Avatar
Just to clear that up a bit, you need a 3-channel ABS rear (not series carrier).
A 2-3 series might be mistaken as a 2-3 series carrier, which is a type of posi.
Everything else is right though.
Old Jan 8, 2011 | 01:04 PM
can you clarify? what is 3 channel abs? and what is 2-3 series carrier? like i said, i am a noob at rears. just trying to learn the basics.
Old Jan 8, 2011 | 01:20 PM
is that all that 4th gens came with is 10 bolts, nothing else?
Old Jan 8, 2011 | 01:21 PM
RamAir95TA's Avatar
The "carrier" is just that - it carries the gear. Basically the posi unit. Cars with a 2.73 (or 3.08 for some V6 cars) came with a 2-series carrier. Anything with a 3.23 and up gear ratio had a 3-series carrier. You can't use gears designed for a 3-series carrier in a 2-series carrier, and vice versa. This really won't pertain to you if you pick up a rear out of another car. Just make sure it's from a V8 car. Ideally you want a rear out of a 94+ M6 car (came with 3.42s) and ALL V8s came with posi.
A 3-channel ABS rear uses a single sensor on top of the differential, while a four channel ABS car has a sensor on each wheel. As mentioned, you want a 3-channel rear (with the sensor in the differential). 3 channel ABS came on NON-TCS cars.
Old Jan 8, 2011 | 01:56 PM
yeah thats what i meant. couldnt think of the word at the time. but yes you are correct. 3 channel
Old Jan 8, 2011 | 02:23 PM
gregrob's Avatar
If you use a 98+ rear you will have to make new brake lines.
Old Jan 8, 2011 | 08:18 PM
not a problem for me. forgot to mention im doing abs delete so im not worried about abs. i would really like a disc brake setup on the posi though. my current diff is drum. is there anything i would have to change or can i just simply connect the lines?
Old Jan 8, 2011 | 08:22 PM
and i dont think this diff swap woulld be a problem with anybody for the street stock class at the shootout correct???
Old Jan 31, 2011 | 10:10 PM
so i put a wanted ad on craigslist. some guy replied that he has a 10 bolt posi with disc and 3.42's.... how can i tell if it really is a 3.42 posi assuming it is out of the car??? how do i even know it is from a '94 z28 as he said it was??
Old Jan 31, 2011 | 10:12 PM
RamAir95TA's Avatar
Easiest thing to do is mark the brake rotor and turn the pinion yoke and count the revolutions. Every 3.42 turns of the yoke should result in exactly one turn of the axle.
Old Jan 31, 2011 | 10:15 PM
its gonna be hard to tell when it gets to that .42.... should i round it off to roughly .50?
Old Jan 31, 2011 | 10:17 PM
dude just said its from an auto. you say only 3.42's came with the manuals???
Old Jan 31, 2011 | 10:26 PM
RamAir95TA's Avatar
No autos came with 3.42s - only V6 cars with the Y87 package. Autos either had 2.73s or 3.23s, nothing else.
The difference between 3.42 and 3.23 is still substantial enough to tell by rotating. You'll see!
Old Jan 31, 2011 | 10:29 PM
is the 3.23 a posi? i might get it anyways. its local (2miles) and cheap ($200) and i can probably talk him down to 150
