Best front brake upgrade for road racing
If I was getting into road racing my thoughts would be:
98-02 2 piston caliper upgrade
Stainless steel brake lines
Brembo blanks & a nice set of pads
Put in some nice brake fluid while I'm at it
Honestly, my first move would probably be sending Sam Strano a PM or e-mail though...not to be a nut swinger, but he knows his ****
![Nut swinger](https://ls1tech.com/forums/images/smilies/nutswinger.gif)
If you have the wheel size either the CTS-V swap, or I know SLP had some Camaro takeoffs that are almost a direct bolt on to a 98-02 spindle, just have to drill out 2 holes. I know the camaro takeoffs fit in a 19" wheel, not sure how large you need to go for the CTS-V. For a 17" wheel the C-5 swap is your best bet. These are all the more cost effective swaps, performance friction has some really nice calipers, and bear make some nice kits but you are going to spend a small fortune.
Village Troll ![](http://jameskellock.tripod.com/sitebuildercontent/sitebuilderpictures/rsman.jpg)
Honestly, my first move would probably be sending Sam Strano a PM or e-mail though...not to be a nut swinger, but he knows his ****![Nut swinger](https://ls1tech.com/forums/images/smilies/nutswinger.gif)
The 98-02 brakes have taken San to quite a few championships, with quality rotors, stainless lines, fresh brake fluid and some GOOD pads. Going to the C5 brakes can be an upgrade, but most say it's more of an appearance mod than performance.
Check out the brakes and suspension section, there's a lot of information on this subject here.
