need help
Old Jan 17, 2011 | 09:13 PM
lovemyzroc's Avatar
Default need help
i am about to buy a timing chain and gears set. the camshaft sprocket is easy!!!! but i need to know how to pull the crankshaft sprocket off. then once you get the old one off how do you put the new one on?
Old Jan 17, 2011 | 09:15 PM
RamAir95TA's Avatar
Pull off, push on. Simple.
If you can't pull it off by hand use a 3-jaw puller.
Old Jan 17, 2011 | 09:19 PM
lovemyzroc's Avatar
its as easy as just pushing it back on? no hammering or anything like that?
Old Jan 17, 2011 | 09:26 PM
RamAir95TA's Avatar
Yep...just lightly tap it on using a piece of pipe or equivalent.
