Coolant crossover tube/steam pipe
I used 1/4npt brass fitting from lowes too. Used fuel line for the hose since i wasn't sure if vacuum hose could stand up to the pressure. When I took off the crossover tube, the banjo bolt was completely clogged with dexcool.
Not clogged with Decool, when GM switched to Dexcool and 100K flush they added clay tablets to stop minor leaks. The clay is the problem not the Dexcool.
Anyone trying to restrict the flow to something like stock? Seems to me the posted pics would all flow a LOT more, not sure if that would be good, bad or indifferent????
