lt4 heads
Port size is not the only thing, shape and a few other key characteristics are critical and the LT4s are NOT right as cast.
I agree about the bench racers, but sure I could put a gm847 cam in my car for braging rights, it would sound cool, but it is not the most effecient setup with stock heads. That's why a hotcam has been apealing to me, it would put me to at least 300rwhp and perfect drivability. I plan on building a turboed 383 in the future, but the hotcam with 1.7 roller rockers, and all the bolt ons will keep me more than satisfyed. I'm with you I want proven results, I just ask questions when it concerns ltx motors because the whole fuel injection thing is new to me, I'm used to carbs and points.
There really is not a case where I would use them, the LT1 head can go 9s in a perfectly setup drag car NA and beyond that I would go to an aftermarket casting. By then you are going to need longer valves to get enough spring in them anyway so the one good thing about the LT4s would no longer matter. Sort of like a factory 4-bolt main, by the time it is necessary you should have aftermarket caps anyway.
