Cheap LT4KM?
Old Jan 29, 2011 | 04:11 PM
LSWHO's Avatar
Default Cheap LT4KM?
Is there a place to get one? I've got 4,000,000 degrees of false knock. I drive backwards in 'D.'
Old Jan 29, 2011 | 04:59 PM
Adam96z's Avatar
Summit has them for $75. I called a friend that works at a GM dealer and he said GM cost is $75, so its probably the best price anywhere.
Old Jan 29, 2011 | 07:18 PM
05HD's Avatar
Originally Posted by LSWHO
PM me for details on the "Get Gregrob laid fund."
Old Jan 29, 2011 | 07:25 PM
whytryz28's Avatar
PM sent for the details.
Old Jan 29, 2011 | 09:09 PM
wrd1972's Avatar
Better ****** up the $75 one from Summit before they are all gone.
Old Jan 29, 2011 | 09:16 PM
SoxXpupPeT's Avatar
agreed. unless you just send your PCM out to get tuned. The tuner should be able to desensitize the knock sensor.
Old Jan 29, 2011 | 09:58 PM
myltwon's Avatar
doesn't gmpartsdirect have some for cheap?
Old Jan 29, 2011 | 10:11 PM
MasterTomos's Avatar
^I believe they stopped making them
Old Jan 29, 2011 | 10:49 PM
Puck's Avatar
Sounds like you already have a datalogging cable(which everyone should own IMO) so you should desensitize it through the tune.
It is easy to do, just be absolutely sure it is false knock. I forget the exact names but the process is simple trial and error. Lower the table values that control how much it pulls, and raise how much it gains. Essentially does the same thing as the LT4 KM but is nearly infinitely adjustable .
Old Jan 30, 2011 | 11:06 AM
pboxfun's Avatar
amazon sells them cheap!
Old Jan 30, 2011 | 01:32 PM
myltwon's Avatar
ah ok, I wasn't sure because I haven't looked for one of those since like 2004
