what cube LT1 should i build??
didnt say 3k was my rock solid budget, just that id like to stay under that for a short block. most 396 rotating assemblies im seeing run from 1700 to about 1900 in most cases which leaves me another 11-1300 to machine the block i already have and balance the rotating assembly more accurately. i think i can come close on a 3k budget. although ive never set out with a budget and been able to stay under it. always go into overkill mode and overbuild, but at least im trying a budget....
Unless or until someone builds us a block capable of a 4.125 or larger bore a 396 would be the biggest one I'd do personally. The 383 is the most common and there are plenty of rotating assemblies available both cast and forged cranks, also unless you have a monster set of heads I'd just do a 383.
well i was origianally going to go with a 399 but i was concerned about all that extra stroke spinning in the stock block.....if i was staying in the low to mid 7000 rpm range it would have been ok IMO....but knowing i would see 8000+ i was afraid of the extra strain on the block......i went with a 385...3.75" x 4.040 bore
I chose the 396 route. Mostly because the crank and machine work was going to cost the same whether I bought a 3.875 crank or a 3.75 crank. And actually, my motor ended up being 392 ci because the block only needed to be bored .010 over.
Damn people need to get out and actually try things and talk to people instead of being bound by the confines of the internet.
A 408 requires no extra clearancing as compared to a 396. It also requires no more trick or expensive parts than a 396...
It's all readily available quality parts that will drop right into an LT1 block. Its been done, nothing special.
Dont know where the myth made its way into Ltx folklore but it's not a big ******* deal.
How in the hell would the 408 be "pieced together"?
Isn't the block sometimes a bit thin and needing sleeves to run that big of a bore?
#32
#33
#34
383 ci = 4.030 bore x 3.75" stroke
396 ci = 4.030 bore x 3.875" stroke
408 ci = 4.030 bore x 4.0 stroke
Formula to figure ci displacement:
bore x bore x stroke x number of cyl x .7854 = displacement
#35
355.....3.48 Stroke 4.030 Bore
383.....3.75 x 4.030
396.....3.875 x 4.030
408 I'm not sure how its done with an LT1???
im assuming jamming a 4" stroke in the block with a 4.030 bore???
cause theres no way your boring the stock block to 4.125"
#38
#40
