Supercharger?
Old Feb 3, 2011 | 06:15 PM
Shark0058's Avatar
Default Supercharger?
Just bought a 94 z. Though i was told it was a bad idea, a tune solved all the probs and its pretty darn mean. Was wondering if i could go with a s/c with this setup?
94 Z28
1500 miles on trans and engine
11.8 to 1
Srp Pistons
Eagle Crank and Rods
TCI trans manual valve body
3500 Stall
255 walbro fuel pump
X nitrous system (100SHOT)
Ported and Polished Stock Heads
306 Cam
1.6 RR
K&N Intake
Trick flow elbow
UD Pulleys
Long tube headers
Texas speed true duel exhaust with x pipe
Old Feb 3, 2011 | 06:17 PM
LSWHO's Avatar
That compression is way too high for boost. I'd aim for sub 9.5. If it were my build I'd actually shoot for about 8.5:1
Old Feb 3, 2011 | 06:23 PM
323steel36's Avatar
vortech my friend installed his recently sound evil.
Old Feb 3, 2011 | 06:30 PM
96TransAmboosted's Avatar
Compression is going to kill you man, just buy a nitrous kit before you blow it up
Old Feb 3, 2011 | 06:31 PM
Shark0058's Avatar
Already have no2 all i want is to be in the low 12s this spring
Old Feb 3, 2011 | 06:32 PM
MasterTomos's Avatar
+1 Compression is way too high.
LSWHO's Avatar
You need more practice if you can't hit low ELEVENS in that car without the spray.
Old Feb 3, 2011 | 06:34 PM
That setup should run low 12's absolutely no problem with 100 shot...unless you're racing up hill or on top of a mountain, I'd expect 11's all day probably even without the spray.
Whats suspension setup are you running?
Btw, ATI Procharger>Vortech in the world of superchargers.
WhistlingZ's Avatar
That compression is way too high unless you are planning on running E85 and/or race gas all the time.
Get yourself some good tires and launch that car well into the high 11's.
Old Feb 3, 2011 | 06:37 PM
Shark0058's Avatar
Im in a pretty high elevation, and the susp mods are um slicks lol just bought it
