What else do us LTx guys need?
Old Feb 4, 2011 | 12:05 PM
  #41
Money1's Avatar
Opti that will spin up to 10K.
Old Feb 4, 2011 | 12:19 PM
  #42
moderate Z28's Avatar
Originally Posted by SS MPSTR
You the man...I'm in for one of the first of these.
X2 but Im unsure of where the filter will be placed. I wont have bumper or A/C stuff, but I think I want to keep my T/A foglights.
Old Feb 4, 2011 | 12:24 PM
  #43
speedracer2536's Avatar
There is no way for you to make a "ram air" and keep the ac.. The condenser is in the way..
Old Feb 4, 2011 | 12:54 PM
  #44
ks my ss's Avatar
Originally Posted by joelster
How would there be enough tension for the crank to spin the p/s and the alternator?
It looks like all three pulleys are right in line with each other. If that is the case the belt will only touch maybe an inch of the balancer pulley on the top and at the bottom. That won't be enough grip to spin the 2 acessories. Maybe i'm looking at it wrong or something though.
Since the LT1 uses a pigback style under drive pulley you can run a belt off of each of them. So there will be 2 really short belts.
Old Feb 4, 2011 | 12:56 PM
  #45
joelster's Avatar
Ah I see. That makes more sense. Each belt would wrap around the crank pulley quite a bit.
Old Feb 4, 2011 | 01:08 PM
  #46
ks my ss's Avatar
Bingo! I am also able to just run the alt. if I wanted as well by just taking off the power steering belt.
Old Feb 4, 2011 | 01:16 PM
  #47
merim123's Avatar
on the PCM issue, it would be ideal to use factory computers so we can keep all the tuning options open. like the 411pcm without the eficonnection cost.
Old Feb 4, 2011 | 05:02 PM
  #48
1961ba427's Avatar
Originally Posted by Wicked94Z
teaser for the "oil pressure saver"
More info on an oil pressure saver? I know it has something to do with the drive under the intake, but how does it work?
Old Feb 4, 2011 | 05:41 PM
  #49
Wicked94Z's Avatar
it will bolt on top of the oil pump drive, with the tabs to lock it in place. So if the composite drive breaks, the drive will not be able to pop out of engagement with the oil pump shaft. I will get a quote from the waterjet guy on monday, 12ga steel should work nicely.
Old Feb 4, 2011 | 05:57 PM
  #50
Wicked94Z's Avatar
I'm upgrading the stock PCMs to handle the additional RPM, it'll be an easy 5 minute swap
Old Feb 4, 2011 | 06:11 PM
  #51
VinR1's Avatar
A roots blower that fits under the cowl...like the ls1 Maggie
Old Feb 4, 2011 | 06:36 PM
  #52
hitmanws6's Avatar
+1 on the roots blower, all the prototypes have fallen through. I think a drop in LS1 lid swap would sell as well. Maybe an affordable alternative intake besides a single plane connversion, something between stock and the miniram. I remember seeing a post about a TIPS 383 being tested with a stock ported LT1 and a Miniram and the Miniram made over 30 more at the crank, so roughly 25 or so more at the wheels. Im sure if a proven design could be made for $4-600 it would sell.
Old Feb 4, 2011 | 06:49 PM
  #53
LVZ2881's Avatar
How about a ready to go, bare 8.8 housing w/ TQ arm mount. For those of us with no welder or fab skills. Make it ready to swap into the 4th gen, with all mounts. Just have the buyer purchase axles, carriers, gears, bearings, etc....and the buyer can have it assembled locally.
Let me know when the oil pressure saver and coolant crossover are ready.
Old Feb 4, 2011 | 06:57 PM
  #54
brokenbird's Avatar
Big-cube capable aftermarket block, but we all know how that is going, lol.
An aftermarket single plane intake that is molded for LT1 intake bolt pattern.
A kit for replacing the rear coolant crossover tube with fittings and a braided hose.
im in for one of these
Old Feb 4, 2011 | 07:28 PM
  #55
3DFORMULA's Avatar
And you can take it a step farther and keep the power steering
more info and pics on this. I noticed the underdrive pulley being capable of being used when I did my alt. relocation. But what power steering pump/mount bracket/pulley? I'd really like to do an old school type of pump with it's own fluid container, instead of our remote fluid container.
Old Feb 4, 2011 | 07:47 PM
  #56
flyinZ's Avatar
I like this option. Then, you'd be able to run a SR engine, w/o having to run an aftermarket PCM..That would be enough, to make me switch my top end over, to a solid setup
Keep the good ideas coming!
Old Feb 4, 2011 | 07:53 PM
  #57
myltwon's Avatar
18 degree heads lol
Old Feb 4, 2011 | 07:54 PM
  #58
myltwon's Avatar
oooo this too
Old Feb 4, 2011 | 09:04 PM
  #59
gregrob's Avatar
Originally Posted by myltwon
18 degree heads lol
That's easy
Old Feb 4, 2011 | 09:31 PM
  #60
LTXBOI's Avatar
I've got a few things on the table for improving the LTx platform...
Plug-n-Play Optispark Eliminator
"Oil Pressure Saver" previously discontinued
Opti-housed cam sensor for aftermarket EFI systems
Fiberglass molded over-the-radiator intakes (filtered & open ram-air versions)
Modified 7000+ RPM capable PCM, possibly with low-Z injector capability
AFFORDABLE 7500 RPM Capable Hydraulic Roller valvetrain package
Any suggestions, or things that you would like to see brought into the dying LTx aftermarket? Like previously mentioned, this isn't my road to early retirement, but I do enjoy R&D and seeing useful products come to life so lets hear it
*AN coolant crossover*
*over the radiator for T/A bumper*
Glad to see someone showing anitiative for the ltx scene...Been following ur threads since the day i seen ur car up close, in action...Keep us posted!!!!
