should i chang cams?
FWIW, I'm running a 228 cam, 4200 converter, 4.88 gears (with 30" tires, so equivalent to about 4.10's with 26"), and at about 3800 lbs, and with the stock PCM I'm at the limit of utilizing the rpm potential of my cam. 60's are in the mid/high 1.4's and 1/8 mile in the 6.9's @ 97 at nearly 500 lbs more than you. I'm not saying that to brag, but to illustrate that you have a lot of potential in your present combo when you get the heads back on, everything properly set up and tuned.
