help me pick gear / tire
Old Feb 8, 2011 | 09:52 AM
quik95lt1's Avatar
Originally Posted by Colin91Z
Yeah Mike your a bit late to the game, I ordered my S60 with 4.30s over two years ago....
i didn't know i called strange the begining of last year looking for 4.30's and they said they didn't have em i had to go to a 4.56......this is good news i thought i was gonna have to go all the way back down to 4.11's
Old Feb 8, 2011 | 10:04 AM
05HD's Avatar
Agreed on radials and a gear banger being a bad combo. You need a soft sidewall to soak up the shockload or carnage will ensue. The truetrac is also definitely a bad choice for drag racing. A spool or a clutch posi and some big bias plies is the way to go.
Old Feb 8, 2011 | 10:13 AM
quik95lt1's Avatar
^ Detroit LOCKER FTMFW!!!!!! i been running my S60 and locker for 3 years and never had an issue and the car launches straight every time......***** mint!!!
Old Feb 8, 2011 | 10:15 AM
SS RRR's Avatar
Village Troll
As tall as the sidewall is for a 28" tire it will be fine.
Old Feb 8, 2011 | 10:39 AM
Colin91Z's Avatar
Hmmm....so we both have S60s...you have 4.56s, I have 4.30s...You need a set of 4.30s, and I would like to step up my gearing to 4.56s....maybe we need to make a trade
Old Feb 8, 2011 | 10:47 AM
quik95lt1's Avatar
sounds like we got a plan here colin.........what series carrier does the 4.30 go on? is it the 5 series or the 3 series??
Old Feb 8, 2011 | 10:56 AM
Colin91Z's Avatar
Good question, I think its a 5 series but I need to go dig up my paperwork to be sure...
Old Feb 8, 2011 | 02:34 PM
gregrob's Avatar
I agree the Det locker is badass, but not for a stick car. If I step up to a Th350 and am having troubles with the truetrac Ill swap it. I've seen plenty of 10 sec cars with the true trac though, so I guess well see how it holds up.
Originally Posted by SS RRR
HA, Classic. (on the pic)
Im thinking so too. You air down 28" radials and they still have some pretty damn good sidewall to soak the hit...
Old Feb 8, 2011 | 03:21 PM
05HD's Avatar
I don't have a huge pile of broken parts and 15 years of experience to back up what I said or anything. I'm just repeating what some other assclown typed in on teh intrawebs. You guys have fun shredding driveline parts all over the place because radials are better and you are smarter.
Old Feb 8, 2011 | 03:27 PM
gregrob's Avatar
So radials are gonna break my S60 and chromoly driveshaft?
Old Feb 8, 2011 | 03:41 PM
05HD's Avatar
You will break whatever the weakest link is if you drive it the way it should be driven on radials. Some times that is a u joint or a true trac diff or the transmission or what have you. That is why I said drivetrain, not a specific part.
Old Feb 8, 2011 | 03:46 PM
  #32
gregrob's Avatar
Ok. A lot of guys are saying start w a bias ply to dial in, then switch.
Old Feb 8, 2011 | 04:21 PM
  #33
SS RRR's Avatar
Village Troll
I'm not quite sure what I believe coming from you. Honestly I'm on the side of you being a hack. What you've typed in this thread thus far is nothing more than thoughtless blanket statements. What you typed ^^^ right there applies to any driveline no matter what parts are behind it.
Old Feb 8, 2011 | 05:08 PM
  #34
05HD's Avatar
You don't have to believe anything. I'd prefer it if you never replied to another post of mine, all you do is waste time and bandwidth on this forum.
Old Feb 8, 2011 | 06:05 PM
  #35
SS RRR's Avatar
Village Troll
When you type stupid **** like what you stated on this thread as well as a few others then you may get called out on it. I would encourage you to do the same.
Old Feb 8, 2011 | 06:16 PM
  #36
05HD's Avatar
I haven't posted any stupid **** in here, just facts based on personal experience. You are the only one wasting time and bandwidth. So, for the sake of the forum, I ask you again, please stop posting.
Old Feb 8, 2011 | 06:24 PM
  #37
SS RRR's Avatar
Village Troll
I see. So you type generic nonsense, get challenged and cry. There is absolutely nothing wrong with running a 28" radial w/ a M6 car even if it's a 16" wheel. There is plenty of sidewall to absorb driveline shock. You can do whatever you can w/in the f-body aftermarket and your wallet and there will always be a "weakest link." Just hush already, parrot. Why not research that question you posed awhile ago regarding what actually causes an engine to decelerate since you couldn't answer it for yourself.
Old Feb 8, 2011 | 06:32 PM
  #38
AChotrod's Avatar
I took off my Bias ply tires and went back to radials after seeing Alans car go wheels up with them. If you do go bias get stiff wall slicks or put tubes in them. My car was almost bouncing the rim off the ground with 28QTPs and 14psi killing ET and MPH.
Old Feb 8, 2011 | 06:56 PM
  #39
05HD's Avatar
Let us review our posts in this thread. First, I posted a suggestion to the OP based on experience. You replied with some childish picture and a flippant remark that the OP would be fine on radials. I then replied basically believe what you want. You responded with a personal attack and then another. You have no facts, just personal attacks. You are a waste of time and should be banned from here internet warrior.
Old Feb 8, 2011 | 07:01 PM
  #40
gregrob's Avatar
https://ls1tech.com/forums/wheels-ti...ials-come.html
