help me pick gear / tire
As stated, a 28" radial will work fine with a manual driveline, and no matter how strong you think you've built means for torque to travel through, there is always a weak link. Always and forever. Care to counter that with something other than your whining?
What say you about those who run the 275 radial class and launch off a trans brake?
Those are all statements of fact. Care to dispute any of them?
I do not see how the driveline beyond the transmission can be loaded before launch. Care to explain? I am no automatic expert, however from what I have been told by those who know more about it than I do, a transbrake launch can be as violent as a launch from a manual.
As far as the other mumbojumbo, you came into this thread, repeating crap that has been preached like the voodoo regarding 26" radials, and promising the OP that "carnage" would ensue if he didn't use a bias ply tire. Retarded.
if u run a slick make sure you get one with a stiff side wall soft side wall slicks dont like the shock from a stick shift
and heres a pic of a my on 295 M/T's on a 8 wide rim with 5.5"BS so you can see what they look like on a car
i had to roll my finders but mine squats realy hard on the right rear left tire didnt rub
I say a bias ply absorbs more shock than an equivalent size radial every time. Stick shift cars are less prone to breaking parts on bias plies. This is absolutely true and no logical argument can be made against it regardless of tire size or any other variable. Call me a parrot if you like, I know I am correct from real world experience. Some things you hear on the internet are actually true. If you don't believe me, head down to your local racing tire dealer and poke the sidewalls on a few tires. Make sure to post back what you find out about sidewall stiffness for all of the readers on here.
Just like the other thread where I tried to get you to answer how an engine decelerates I see you have completely avoided your claim on how a trans brake is able to load the driveline past the transmission. It is things like this that makes me believe you are a hack. Please enlighten me how it is possible for a transbrake to load from the trans to the tires and I will then change my opinion. Until then, parrot/hack.
My not answering you doesn't indicate that I do not know the answer. I also absolutely do not care even the slightest bit what you think of me. What is the relevance of the proper procedure to preloading the driveline on a transbraked auto to this thread?
Your avoiding and not answering yet another one of your ridiculous claims and then trying to desperately spin what I say to fit your idiotic agenda just proves once again you have no idea what you are talking about. Those on this site as well as others who've mouthed off about whatever experience they want to claim have always been proven a joke. You are pretty much there.
Now, since I don't feel like helping you learn, go and figure out how to preload the driveline on a transbrake car for yourself and then come back here and apologize to me again.
OP, go with the bias ply.
are hoosier drag 28x10's at 12psi........they are a little interesting to drive like that too on the high end at 130mph+ too lol
I can't remember if you have an auto? Since 05HD is holding his secrets so dear to him, can you explain to me how you can load up the drivetrain while the transbrake is engaged? Thanks.
now back on topic........i may or may not have just installed a transbrake in my 4l60E
........as far as i know there is no way to "preload" the suspension/driveline from the trans back with a tbrake.......the brake as im sure you know locks the trans in first and reverse to hold the outputshaft from turning.....hypothetically like in my case with at 5300 stall the motor should go to 5300rpm....when the button is released reverse dis-engages and the energy is allowed to spin the output shaft...........its essiantially like me having a stick and dumping the clutch at 5300 lol.....but i still get a little torque multiplication after that........ohhhh man i cant wait its OTB time!!! haha
now i do know there are systems avilable to allow you to "creep" the car forward by pulse width modulating the soleniod for reverse....however i cant see how that could efficently be used to load the drivetrain.......
If you want to look for bullshit in this thread, look no further.
........lets talk gear/tire and brakes!!!
