DD cam
Old Feb 8, 2011 | 10:11 AM
myltwon's Avatar
driveability tune and gears will make the car much nicer to drive. that cam is too small to be acting that big.
Old Feb 8, 2011 | 10:20 AM
bowtienut's Avatar
For NA operation with excellent heads and cam durations in the 220's-230's range and lift in the high .5xx's or more, you get to a point of diminishing returns with increased exhaust lift and duration, maybe gaining a few ponies up top but usually at the expense of overall powerband.
My cam lobes have equal I and E lift, but I'm running 1.6 I and 1.5 E rockers, so I have LESS exhaust valve lift. I drop to 5400 on the shifts, so I can't afford to give up midrange torque.
Old Feb 8, 2011 | 10:25 AM
quik95lt1's Avatar
pat that was the killer on my motor..........i dont make as much midrange as you do..........i was dropping from 8000 to 5900 on my shifts with the 4000 stall and i could NOT get the car to go any quicker than 10.6 @ 128......i went up to a 4800 stall and my shift extension changed from 8000 to 6400.....that change alone i picked up to 10.3 @ 131 then some other things and bang 10.2 @ 132........my powerband rises and falls quickly at 6500 and 8100.......im going up to a 5300 this year hoping to keep it buzzing between 7000 and 8000 through all gears
OP like pat said and i did earlier.....the converter and gear depends ALOT on the ability of the car to accelerate to its potential.......
Old Feb 8, 2011 | 10:38 AM
bowtienut's Avatar
Mike, that shift extension dilemma is killing me. I tried a different converter (9.5" custom) that flashed to 4800 on the launch and kept the rpm at 6000 after the shifts, but I gained nothing compared to this super-efficient little 8" ATI that only flashes to 4400. The 9.5 just didn't keep the power hooked up in the upper revs like this one does. I even spoke at length to Charlie at ATI about it, and he's convinced if he loosens this one it will behave like the 9.5 I tried. If I had your rpm potential, I'd be running a lot looser than I am!
Old Feb 8, 2011 | 10:42 AM
speed_demon24's Avatar
Hitman is right on the money.
A dyno tune doesn't mean squat for driveability. Part throttle/low rpm tuning is what you need, and that takes some finess/experience, not just tweaking WOT timing and mixture on the dyno.
Even with your gears, a competent tuner can make that 228 cam very driveable. I have a 228 in mine, PCMforLess mail order tune handles all the driveability aspects just fine, we just tweaked the WOT mixture and timing on the dyno.
Your converter soaks up all the cam surge. Bucking/surging gets old around town as well as not being able to just lug around at 1500 rpm's. My dad's ls1 ws6 with a 212/218 is 10x more fun to drive around town. It drives just like stock and has off-idle torque which I miss. Even though it's probably down 30-40rwhp it feels just as fast as mine too.
Old Feb 8, 2011 | 10:47 AM
bowtienut's Avatar
Did you see my other post? :
"And BTW, my cam is a 108 LSA.
I can manually lock the converter and lug it; no surging or bucking."
Old Feb 8, 2011 | 10:56 AM
quik95lt1's Avatar
yea i know id pick up huggeee with the ATI converter but then i'll never drive my car again......i take pride in running 10.2 then driving 50 miles to a car show with it lol.......and mudering the occasional LS1 on the highway lol......but yea we are loosening my 9.5" Vigilante up to a 5300 and I'll still have my lockup so i can cruse at 75mph nice nice.......if i ever switch im going th350 with a serious converter......like a 5800 or so lol
yep my car is smooth as silk with the converter......just outta curiousity i pressed my lockup button in second gear around 2200rpm and i almost bucked the teeth out of my head lol mine stays a little chunky up till aobut 2700 then it smooths out
Old Feb 8, 2011 | 11:04 AM
bowtienut's Avatar
You would be shocked how snappy that 8" feels. I guarantee much tighter feeling than your present Vig. That 9.5" 4800 I tried was nowhere near as driveable. And with my 4.88's and 27" street tires, lack of lockup is no issue. The B-bodys have a pretty stout tranny cooler arrangement.
Old Feb 8, 2011 | 04:53 PM
Wicked94Z's Avatar
Yup, I'm convinced an 8" converter is the only way to go unless you're making more than 800 hp. The weight, efficiency, flash rpm, etc are great for 95% of cars. Mine is loose, I'm throwing some hy-gard in it to tighten it up hopefully to the 5300-5400 range, then in goes a 15 degree bigger cam later that will let me use all that converter. If I was building a h/c or cam only car I'd be tempted to use a 7". I'll bet mike would go 9.90s with a th350 and converter change
Old Feb 9, 2011 | 06:42 AM
bowtienut's Avatar
Originally Posted by Wicked94Z
...... I'm throwing some hy-gard in it to tighten it up .....
How does that work? What does it do to the trans?
Old Feb 9, 2011 | 07:35 AM
quik95lt1's Avatar
I'm goin 9.90 or less with just the changes I'm making now ...........
then maybe in goes the right trans/converter
but yea what pat says how does that work???
PM us if u want so we dont hijack this dudes thread
Old Feb 9, 2011 | 08:31 AM
  #32
Gojira94's Avatar
Getting back to cams, I'd like some opinions of this one:
228/232 113LSA 109ICL
.552 .547 on 1.6RR
paired with 190cc heads (AI), longtubes, dumped 3" Xpipe / 2 chambers, 3200-3600 Circle-D stall, stock forged rod bottom w/ ARP bolts, 3.73 gears.
Old Feb 9, 2011 | 08:42 AM
  #33
quik95lt1's Avatar
.552 .547 on 1.6RR
based off of a 3600 stall......for a street strip cam i like it........maybe give it a hair more exhaust duration like 228/234 but yea i like it......did AI spec u that cam??
Old Feb 9, 2011 | 08:54 AM
  #34
Gojira94's Avatar
My specs, wanting something more than the 503 in my A4 car, with less lift than the XFI280 (467). I thought shortening the exhaust duration would help prevent over-scavenging with a free flowing exhaust and efficient exhaust ports on the AI 190cc heads. Aiming to cross the traps near the top of 3rd at about 6300. I'll keep in mind adding 2 more degrees exhaust duration and see what AI has to say about the duration spread as well. Thanks for the opinion.
Old Feb 9, 2011 | 12:10 PM
  #35
96capricemgr's Avatar
Wasn't lack of lowend one of your complaints with your old setup? Wasn't that much improved by replacing popular parts with good ones?
Old Feb 9, 2011 | 02:39 PM
  #36
1961ba427's Avatar
Originally Posted by gregrob
It's a 6 speed!
I like the XFI 466 for a shelf cam.
Or CC503 with 1.7's.
If you want something a little more custom keep it at or under the sizes of those two.
I have BOTH of those sitting on the shelf awaiting my builds. One for my 97 SS M6 & one for my gf's 95 Z28 M6. I can't make my mind up which one is going in my car. When I say both, I mean down to the 1.6 with the 466 & 1.7's with the 503.
Old Feb 9, 2011 | 03:32 PM
  #37
gregrob's Avatar
Bizzarre.
I've used the 466 with a custom LSA and it worked awesome on a LE2 car, 411 RWHP.
I want to try the 503 on a buddies bolt on / stalled 94. Just gotta talk him out of the hotcam.
Old Feb 9, 2011 | 03:54 PM
  #38
wrd1972's Avatar
OP you need some 4.10's to resolve most of these issues. I am running a LE 224/230 on a 107LSA and and there is only a hint of surge under 1.8K RPM but it does not bother me and yes it has a good tune. The tires bust loose at 2.5K RPM and peak power holds on till 6.4K RPM too.
If you are determined to not change the gears, you will simply need a tamer cam like the 503 or maybe even a little less. And as already stated, you might run into the intake runners on the heads being too big for the cam.
You should call Lloyd and talk cams.
Old Feb 9, 2011 | 04:41 PM
  #39
Wicked94Z's Avatar
.552 .547 on 1.6RR
That's like an LS1 cam, it's totally incorrect for an LTx application. It's way too wide. The intake is way too late and the exhaust way too early.
Old Feb 9, 2011 | 04:54 PM
  #40
Wicked94Z's Avatar
hy-gard... it's a thick hydraulic fluid from john deere. I'll be running it straight with some red dye added (it's colorless). It's been proven to reduce wear, drop trans temps 10% and tighten the converter 5-10%. It's cheap too, runs about 13 bucks a gallon. If you're looking to loosen up the converter a little with the same fluid temp and wear advantages they make a low-viscosity version
