1.7 rr with a cc305
How would they affect my gas mileage? And what kinda power increase would i most likely get?
The engine has 3k miles on it.
With that cam though it's already kinda big I would aim for under .600 lift to be safe if you can stay under that you should be ok. Anything over that may require a "clay" testing procedure to check it clearing the pistions like MM said.
The only other thing is I don't understand why it isn't run commonly but I don't really care either I plan on buying them also. I figure swapping those chits out are a bitch with all those damm threads why go 1.6?? when I can go 1.7 for the same price.
There is a difference in how it stress the studs though. So to resolve that and add some extra protection I plan on changing our "stock" rocker studs. Which are inside the heads 3/8 th but uptop where you screw on your Rockers it's 7/16th thread which is a bit weaker. I'm gonna upgrade to 3/8th below and up top. Those studs should give some prevention to the added stress of the lift.
WWW.racenet.net has 1.8s!!!!! but I cram to run those without seeing them more commonly, the rockers studs breaking or ripping out would not make for a pretty site while blasting through a 5000 rpm romp.
Calculate your lift example shown using .525 lift w/1.5 rockers.
.525 / 1.5 = .350 so if you ran 1.7's it would be .350 x 1.7= .595 lift.
if your cam is advertised with .526 lift using 1.6 then you have to divide .525 by 1.6=.343 which would would change your 1.7 lift.
Look into those studs if you wanna play it safe. But even then I haven't ran it YET so I can't gaurantee it or give you mileage with them on.
I was thinking along the lines you are, and I already have a set of 1.7's waiting to go on my 224/230 setup, just working bugs out on the car first.
Don't forget you're going to need hardened pushrods (if you don't already have them) and the LT1 guideplates. Thunderracing sells those.
