LT1 Timing chain, which one?
Old Feb 16, 2011 | 10:40 AM
93M6Formula's Avatar
Default LT1 Timing chain, which one?
Hey guys I replacing my waterpump and timing cover gaskets and I figured since I'm in there I might as well get new timing gears and chain since there is a lot of slack and the wear on the gears.
My question is, is there any better chain I can get that will work with the stock gears? And does anyone happen to know the part # for the GM 93 LT1 timing gears?
Thanks for the help
Old Feb 16, 2011 | 11:50 AM
lt1-xjs's Avatar
Thanks for the help
With the stock pump you're limited to the stock chain. I was quoted:
10128485 timing chain
10206039 cam gear
10128346 crank gear
