heated 02 sensor, or no?
Old Feb 15, 2011 | 03:51 PM
fast450ridr's Avatar
Default heated 02 sensor, or no?
I've searched all around for the answer to this question, and haven't found a direct answer.
I'm planning on buying a set of longtube headers for an automatic 1993 lt1 camaro, and was wondering if I will HAVE to buy the heated 02 sensors or not. I know I will need the extensions, but the sensors? It seems like i've seen guys use stock sensors, and others have also bought heated.
Any help would be much appreciated. Thanks
It has an airfoil, thermostat, no cat, and will in the next year have nitrous, stall, cam, ported heads, and everything to go with the cam swap.
Old Feb 15, 2011 | 03:57 PM
05HD's Avatar
No, you don't have to do it. It would be a good idea though.
Old Feb 15, 2011 | 04:04 PM
defaultexistence's Avatar
YES YOU MUST do it...its a no brainer..it will not run properly AND you will not tune it....Case and point
https://ls1tech.com/forums/lt1-lt4-m...t-headers.html
Old Feb 15, 2011 | 04:06 PM
I do plan on doing a pcmforless, or ed wright tune after I get the headers.. Sorry I forgot to point that out
RamAir95TA's Avatar
IMO, you MUST. Long tubes dissipate heat much faster than stock manifolds and move the O2s further away, making it harder to keep them at proper operating temperatures.
Old Feb 15, 2011 | 04:07 PM
05HD's Avatar
I say again, NO YOU DO NOT HAVE TO DO IT. It would be a good idea to do it though.
Old Feb 15, 2011 | 04:09 PM
RamAir95TA's Avatar
I gave reasons why you should convert to heated O2s. Can you give reasons why it isn't necessary? At least give the OP something to think about and make him make an educated choice.
Old Feb 15, 2011 | 04:16 PM
05HD's Avatar
Well, I have a 93 with long tubes on it for quite some time. I was curious to see if it was running in closed loop since I never did the heated o2s. I hooked up a scanner and monitored loop status and o2 activity for a month of daily driving. It only drops into open loop on extended idling, more than 3 minutes. This was good enough for me and I have left it like that for about a year now with no ill effects.
Old Feb 15, 2011 | 04:21 PM
31camaro's Avatar
i ran stock unheated o2's on mine, and it worked fine, o2 sensors read perfect and everything. So NO, it is not necessary.
Old Feb 15, 2011 | 04:23 PM
31camaro's Avatar
im not sure if your being funny or not, but that is a false statement. on a side note i enjoy your sig everytime i read it, lol
Old Feb 15, 2011 | 04:24 PM
whytryz28's Avatar
Necessary is not the same as required.
His car will run on stock 1 wire O2s, of course not as good as if he had heated.
Old Feb 15, 2011 | 05:07 PM
Puck's Avatar
My 93 ran like **** with longtubes until I got heated o2s.
Old Feb 15, 2011 | 07:41 PM
No matter how you look at it...just like you nay sayers Cars and Like mine Was .. it will not run at it potential,It will foul plugs quicker and miss fire,it will bounce in and out of CL at crusing speeds and idle,it will use more gas,it may have idle issues(mine sure did), it will be hard to tune if at all... thicker metal steel headers or wrapping them will retain more heat and may help the situation but will still be running on old technology and not at Potential to complement an Ed Wright tune . do the conversion its just to simple and worth it not to ...
Old Feb 15, 2011 | 07:47 PM
So i'm guessing its just one of those deals of how the specific car will react to it. I can understand where everyone is coming from now.. I'm not extremely picky about the car, so I'm not going to worry about the heated sensors until I run it without them and see how it will react..
Thanks for all the help!
Old Feb 15, 2011 | 07:48 PM
And also, I made sure to put defaultexistence's write-up in my favorites for when i'll need to change them.. lol
Thanks again
Old Feb 15, 2011 | 08:16 PM
96lt1m6's Avatar
I believe heated o2s help vs non heated. There is a reason GM quit the 1-wire o2 back in '94
Old Feb 15, 2011 | 09:03 PM
05HD's Avatar
Yep. That reason was cold start emissions. If a car has a good tune on it, it really doesn't need o2 sensors at all. They are primarily for the benefit of the catalytic converter.
Old Feb 15, 2011 | 10:50 PM
LigHtEmUp01's Avatar
what is a heated 02?
Old Feb 15, 2011 | 11:05 PM
RamAir95TA's Avatar
O2 sensors must be at a very high temperature in order to provide accurate readings. Prior to 1994 the one-wire non-heated sensors relied on the engine exhaust to heat them up. 94+ sensors use a heated element to speed up the heating process.
Old Feb 15, 2011 | 11:21 PM
jaycenk's Avatar
x2 on this and that is one of the many reasons most went to heated O2's around the same time is that it offers a better more reliable reading of the AFR for the new faster PCM.
